Ga door naar hoofdinhoud
KitchenAid KSM150PSER Circuit Board Replacement
Wat je nodig hebt
  1. KitchenAid KSM150PSER Circuit Board Replacement, Circuit Board: stap 1, afbeelding 1 van 2 KitchenAid KSM150PSER Circuit Board Replacement, Circuit Board: stap 1, afbeelding 2 van 2
    • Using a Phillips #2 screwdriver, remove the 10mm screw on the back cover by rotating it counterclockwise.
    • The back cover is now free. Remove it by pulling it back and up.
    • Ensure that the mixer is disconnected from any electrical source prior to removing the back cover.
  2. KitchenAid KSM150PSER Circuit Board Replacement: stap 2, afbeelding 1 van 2 KitchenAid KSM150PSER Circuit Board Replacement: stap 2, afbeelding 2 van 2
    • Using a Phillips #1 screwdriver, remove the 9.5mm screw above the circuit board by rotating it counterclockwise.
    • If you can't see the screw, try pulling the seal down past the wires to make the screw more accessible.
  3. KitchenAid KSM150PSER Circuit Board Replacement: stap 3, afbeelding 1 van 2 KitchenAid KSM150PSER Circuit Board Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Using pliers or tweezers, remove the connectors of the four wires attached to the circuit board.
  4. KitchenAid KSM150PSER Circuit Board Replacement: stap 4, afbeelding 1 van 1
    • Grab the wires and tilt the edge of the board up to lift the circuit board up and out.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Luke Leonard
571 Reputatie
2 handleidingen geschreven
Cal Poly, Team S2-G5, Livingston Winter 2018 Lid van Cal Poly, Team S2-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G5
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 47
Altijd: 5,387
