Ga door naar hoofdinhoud
KitchenAid KSM150PSER Carbon Brushes Replacement
Wat je nodig hebt
  1. KitchenAid KSM150PSER Carbon Brushes Replacement, Carbon Brushes: stap 1, afbeelding 1 van 2 KitchenAid KSM150PSER Carbon Brushes Replacement, Carbon Brushes: stap 1, afbeelding 2 van 2
    • Using a flat head screwdriver, unscrew the brush cap on each side of the mixer by turning them counter clockwise.
    • Remove brush cap by pulling it toward you.
    • The brushes are held in by springs and will fly out if removed too fast.
  2. KitchenAid KSM150PSER Carbon Brushes Replacement: stap 2, afbeelding 1 van 1
    • Remove brush by pulling it toward you.
    • One corner of the brush is flattened. You can check which way the brush is oriented by shining a flashlight inside the hole.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Hayley Young
211 Reputatie
1 Handleiding geschreven
Cal Poly, Team S2-G5, Livingston Winter 2018 Lid van Cal Poly, Team S2-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G5
4 Leden
10 handleidingen geschreven
Één opmerking
I’ve been procrastinating on trying to fix my KA mixer on my own…today I did it. The directions were pretty clear and the only thing wrong was that when I had previously cleaned my mixer, I put the carbon brushes in the wrong way. Once I shined a flashlight into the hole I could see where the notched corner went.
Amber Reimer - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 33
Afgelopen 30 dagen: 145
Altijd: 15,113
