Inleiding
Removing the bowl screw cap is easy and doesn't take long. If the bowl doesn't stay in properly you might want to replace this part.
Wat je nodig hebt
Using a #2 Phillips screwdriver, remove the three 13mm screws holding the bowl screw cap on by rotating them counterclockwise.
Één andere persoon heeft deze handleiding voltooid.
