Ga door naar hoofdinhoud
KitchenAid KSB5CR Ribbon Cable Replacement
Wat je nodig hebt
  1. KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Back Panel Part 1: stap 1, afbeelding 1 van 3 KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Back Panel Part 1: stap 1, afbeelding 2 van 3 KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Back Panel Part 1: stap 1, afbeelding 3 van 3
    • Remove the glass container and place the blender upside down on a solid surface.
    • Remove the four rubber feet using the needle nose pliers.
    • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
  2. KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Back Panel Part 2: stap 2, afbeelding 1 van 1
    • Lift the back panel up, sliding it along the power cord.
  3. KitchenAid KSB5CR Ribbon Cable Replacement, Removing the O-Ring: stap 3, afbeelding 1 van 2 KitchenAid KSB5CR Ribbon Cable Replacement, Removing the O-Ring: stap 3, afbeelding 2 van 2
    • Remove the two #6 Hex 82mm screws using the Phillips #2 screwdriver.
    • Remove the rubber O-ring by lifting it up.
  4. KitchenAid KSB5CR Ribbon Cable Replacement, Removing the Ribbon Cable: stap 4, afbeelding 1 van 1
    • Remove the ribbon cable from the chassis by lifting it up.
    • Remove the other end of the ribbon cable from the circuit board by lifting it up.
Conclusie
Cameron Geehr
745 Reputatie
6 handleidingen geschreven
Cal Poly, Team 12-5, Forte Fall 2014 Lid van Cal Poly, Team 12-5, Forte Fall 2014
CPSU-FORTE-F14S12G5
5 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 492
