Ga door naar hoofdinhoud
KitchenAid KSB5CR Power Cable Replacement
Wat je nodig hebt
  1. KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: stap 1, afbeelding 1 van 3 KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: stap 1, afbeelding 2 van 3 KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: stap 1, afbeelding 3 van 3
    • Remove the glass container and place the blender upside down on a solid surface.
    • Remove the four rubber feet using the needle nose pliers.
    • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
  2. KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 2: stap 2, afbeelding 1 van 1
    • Lift the back panel up, sliding it along the power cord.
  3. KitchenAid KSB5CR Power Cable Replacement, Freeing the Power Cable: stap 3, afbeelding 1 van 1
    • Lift up on the power cable to pop it out of its holder.
  4. KitchenAid KSB5CR Power Cable Replacement, Detaching the White and Black Wires: stap 4, afbeelding 1 van 2 KitchenAid KSB5CR Power Cable Replacement, Detaching the White and Black Wires: stap 4, afbeelding 2 van 2
    • Be gentle with the knife or you will break the circuit board.
    • Slide the knife into the metal loop holding the insulation before the white copper wire, and wiggle it back and forth until it loosens.
    • Pull the wire out from the metal loop that you loosened.
    • Repeat this process with the black copper wire.
  5. KitchenAid KSB5CR Power Cable Replacement, Detatching the Green Wire: stap 5, afbeelding 1 van 2 KitchenAid KSB5CR Power Cable Replacement, Detatching the Green Wire: stap 5, afbeelding 2 van 2
    • Using the Phillips #2 screwdriver, remove the #8 Phillips 6mm screw to which the green wire is attached.
Conclusie
Cameron Geehr
745 Reputatie
6 handleidingen geschreven
Cal Poly, Team 12-5, Forte Fall 2014 Lid van Cal Poly, Team 12-5, Forte Fall 2014
CPSU-FORTE-F14S12G5
5 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 676
