Ga door naar hoofdinhoud
KitchenAid KSB5CR Fan Replacement
Wat je nodig hebt
  1. KitchenAid KSB5CR Fan Replacement, Removing the Back Panel Part 1: stap 1, afbeelding 1 van 3 KitchenAid KSB5CR Fan Replacement, Removing the Back Panel Part 1: stap 1, afbeelding 2 van 3 KitchenAid KSB5CR Fan Replacement, Removing the Back Panel Part 1: stap 1, afbeelding 3 van 3
    • Remove the glass container and place the blender upside down on a solid surface.
    • Remove the four rubber feet using the needle nose pliers.
    • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
  2. KitchenAid KSB5CR Fan Replacement, Removing the Back Panel Part 2: stap 2, afbeelding 1 van 1
    • Lift the back panel up, sliding it along the power cord.
  3. KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 1: stap 3, afbeelding 1 van 3 KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 1: stap 3, afbeelding 2 van 3 KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 1: stap 3, afbeelding 3 van 3
    • Remove the two #5 Phillips 95 mm machine screws using the Phillips #2 screwdriver.
    • Remove the rubber O-ring by lifting it up.
    • Remove the ribbon cable from the chassis by lifting it up.
  4. KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 2: stap 4, afbeelding 1 van 3 KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 2: stap 4, afbeelding 2 van 3 KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 2: stap 4, afbeelding 3 van 3
    • Unhook the white wire that is looped around the peg by pulling it out of the clip.
    • Repeat this process with the red wire on the other side of the chassis.
    • Remove the end cap using the 8" needle nose pliers.
    • Pull up the fan chassis.
  5. KitchenAid KSB5CR Fan Replacement, Removing the Fan: stap 5, afbeelding 1 van 1
    • Remove the fan by lifting it upwards.
    • This step is difficult and requires force. Use of both hands is recommended.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Cameron Geehr
745 Reputatie
6 handleidingen geschreven
Cal Poly, Team 12-5, Forte Fall 2014 Lid van Cal Poly, Team 12-5, Forte Fall 2014
CPSU-FORTE-F14S12G5
5 Leden
3 opmerkingen
Hi,
Do you know if it is possible to convert Kitchenaid Artisan stand mixer to 240v, has anyone looked inside or know if i should change something.
Ancient warrior - Antwoord
Does raplacing the fan mean that the fan itself (when broken) can be ordered? So just the white plastic round part. If so, could someone please give me a reference number? Would be highly appreciated.
Hugo, the Netherlands.
Hugo - Antwoord
my blender turn on all the numbers light at the same time and is not working at all. do you know what the problem could be?
patricia - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 2,233
