Ga door naar hoofdinhoud
KitchenAid KHM512ER Motor Replacement
Wat je nodig hebt
  1. KitchenAid KHM512ER Motor Replacement, Motor: stap 1, afbeelding 1 van 2 KitchenAid KHM512ER Motor Replacement, Motor: stap 1, afbeelding 2 van 2
    • Insert the back of a plastic opening tool into one of the beater holes
    • Apply force to pull the circular plastic part off.
    • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
  2. KitchenAid KHM512ER Motor Replacement: stap 2, afbeelding 1 van 2 KitchenAid KHM512ER Motor Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips 2 screwdriver to remove the two 20mm screws holding the bottom plastic piece in place.
    • Remove the bottom plastic piece using a plastic opening tool.
    • Your screwdriver may not be long or narrow enough to reach the screws in these holes. If that's the case, use another screwdriver.
  3. KitchenAid KHM512ER Motor Replacement: stap 3, afbeelding 1 van 2 KitchenAid KHM512ER Motor Replacement: stap 3, afbeelding 2 van 2
    • Using a Phillips 2 screwdriver, remove the three 20mm screws holding the motor assembly in place.
    • Use your hands to remove the motor assembly and circuit board.
  4. KitchenAid KHM512ER Motor Replacement: stap 4, afbeelding 1 van 3 KitchenAid KHM512ER Motor Replacement: stap 4, afbeelding 2 van 3 KitchenAid KHM512ER Motor Replacement: stap 4, afbeelding 3 van 3
    • Firmly grip the motor in your hand. Using pliers, pull the connectors off the motors.
    • Some force may be required. Be careful not to cut yourself on any electrical components.
Conclusie
[deleted]
134 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 30
Altijd: 4,563
