Inleiding
Adjusting the beater head is a simple process involving only some handling of a screwdriver.
Wat je nodig hebt
Lift the mixer arm and locate the large screw where the base meets the arm.
Using a flathead screwdriver, turn the screw counter-clockwise to raise the beater head or turn it clockwise to lower the beater head.
Once your beater head is at the appropriate height, you're good to go.
6 andere personen hebben deze handleiding voltooid.
3Gids Commentaar
I have a K5ss by Hobbart. Do you know how to adjust the bowl/beater clearance.?This machine does not have the screw that adjusts the clearance like the K45ss does. The manual tells how to turn a screw to adjust the clearance on a k45ss, but says to consult an authorized dealer for the k5ss. I called around and nobody in my area works on mixers. Is this something I can do myself? Any help would be appreciated.
My Beater Head Adjuster Screw hole's threads are damaged, ( I may have crossed threaded the screw) and the replacement screw will not screw in. I need to have the threads chased. None of the local KitchenAid repair locations work on small KitchenAid small appliances, only stoves, friges, ect.
I need someone close 36801 (Opelika Al) and having no luck finding someone.
Any help greatly appreciated
