Inleiding
This is a guide on how to disassemble and remove the heating element from the Kitchen Smith 1.7L Electric Kettle KE01102-UL. It is an easy process and should require less than 10 minutes to complete. As with any electrical device, make sure it is unplugged as you work on it, and avoid water contact with any of the internal parts.
Wat je nodig hebt
At the bottom of the kettle pot, remove two 10 mm screws with a Phillips #2 screwdriver.
