Ga door naar hoofdinhoud
Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly
Wat je nodig hebt
  1. Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly, Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: stap 1, afbeelding 1 van 2 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly, Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: stap 1, afbeelding 2 van 2
    • At the bottom of the kettle pot, remove two 10 mm screws with a Phillips #2 screwdriver.
  2. Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: stap 2, afbeelding 1 van 3 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: stap 2, afbeelding 2 van 3 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: stap 2, afbeelding 3 van 3
    • Open the lid of the kettle
    • Remove two 12 mm screws at the top of the handle with a Phillips #2 screwdriver.
  3. Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: stap 3, afbeelding 1 van 2 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: stap 3, afbeelding 2 van 2
    • The exterior of the plastic handle and lid can now be removed from the kettle to expose the electric components.
    • The plastic cover may need a little wiggling to pop off.
  4. Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: stap 4, afbeelding 1 van 3 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: stap 4, afbeelding 2 van 3 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: stap 4, afbeelding 3 van 3
    • Turn the kettle over to the back of the handle.
    • Remove three 10 mm screws connecting the switch circuit to the heating element with a Phillips #2 screwdriver.
    • The heating element should disconnect, allowing you to remove it.
  5. Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: stap 5, afbeelding 1 van 2 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: stap 5, afbeelding 2 van 2
    • The pronged power element, removed in Step 4, will have a dry-heating safety feature on the opposite side.
    • This switch turns off the kettle once steam is detected, indicating the water is boiling.
    • This is the boil dry protection switch.
  6. Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: stap 6, afbeelding 1 van 2 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: stap 6, afbeelding 2 van 2
    • The inner heating element can now be removed after the completion of Step 4.
  7. Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: stap 7, afbeelding 1 van 3 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: stap 7, afbeelding 2 van 3 Kitchen Smith 1.7L Electric Kettle KE01102-UL Disassembly: stap 7, afbeelding 3 van 3
    • Looking at the bottom of the base, remove two 12 mm screws from the base with a Triangle #2 screwdriver.
    • You are now able to take the black plastic cover off and remove the cord.
Conclusie
Bijgevoegde documenten
Amanda Yan
195 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 22
Altijd: 384
