Ga door naar hoofdinhoud
Kingston HyperX CloudX Speaker Sponge Replacement
Wat je nodig hebt
  1. Kingston HyperX CloudX Speaker Sponge Replacement, Speaker Sponge: stap 1, afbeelding 1 van 1
    • Remove the ear cushion from the earphone.
  2. Kingston HyperX CloudX Speaker Sponge Replacement: stap 2, afbeelding 1 van 2 Kingston HyperX CloudX Speaker Sponge Replacement: stap 2, afbeelding 2 van 2
    • Remove four 11.2 mm screws from the earpiece using a Phillips #00 screwdriver.
  3. Kingston HyperX CloudX Speaker Sponge Replacement: stap 3, afbeelding 1 van 2 Kingston HyperX CloudX Speaker Sponge Replacement: stap 3, afbeelding 2 van 2
    • Use a spudger to pry the top plate away from the motherboard.
    • There will be a groove in between the two plates to insert the spudger.
  4. Kingston HyperX CloudX Speaker Sponge Replacement: stap 4, afbeelding 1 van 1
    • Use the metal spudger tool to scrape off the old foam pad and any remaining glue.
    • The plate does not have to be completely clean after removal, just clean enough to securely attach the new sponge.
  5. Kingston HyperX CloudX Speaker Sponge Replacement: stap 5, afbeelding 1 van 1
    • Line the edge of the headphone plate where the original pad was with superglue.
    • Press the new sponge into the glue and allow it to dry fully.
    • The new sponge may need to be cut to size in order to fit on the headphone plate.
    • Make sure the glue is completely dry before reassembling your device. Failure to do this may result in damage of your device.
Conclusie
Kosie
121 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 127
