Ga door naar hoofdinhoud
Kindle Voyage Wifi Antenna Replacement
Wat je nodig hebt
  1. Kindle Voyage Wifi Antenna Replacement, Back Panel: stap 1, afbeelding 1 van 2 Kindle Voyage Wifi Antenna Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Insert a plastic opening tool between the plastic panel shown on the device.
    • Use the tool to pry the plastic away from the device.
    • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
  2. Kindle Voyage Wifi Antenna Replacement: stap 2, afbeelding 1 van 1
    • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
  3. Kindle Voyage Wifi Antenna Replacement: stap 3, afbeelding 1 van 3 Kindle Voyage Wifi Antenna Replacement: stap 3, afbeelding 2 van 3 Kindle Voyage Wifi Antenna Replacement: stap 3, afbeelding 3 van 3
    • Once the screws are removed, the back panel can slide off the device.
  4. Kindle Voyage Wifi Antenna Replacement: stap 4, afbeelding 1 van 2 Kindle Voyage Wifi Antenna Replacement: stap 4, afbeelding 2 van 2
    • Remove the magnetic component with the magnetic head of the aluminum driver.
  5. Kindle Voyage Wifi Antenna Replacement, Wifi Antenna: stap 5, afbeelding 1 van 2 Kindle Voyage Wifi Antenna Replacement, Wifi Antenna: stap 5, afbeelding 2 van 2
    • Use an aluminum driver with Phillips head #00 to remove the four 3 mm screws shown in the picture.
    • Use the same driver to remove the two 2.5 mm screws.
  6. Kindle Voyage Wifi Antenna Replacement: stap 6, afbeelding 1 van 3 Kindle Voyage Wifi Antenna Replacement: stap 6, afbeelding 2 van 3 Kindle Voyage Wifi Antenna Replacement: stap 6, afbeelding 3 van 3
    • Using the tweezers, undo the attached clip.
    • Remove the three 3 mm screws holding down the rest of the antenna with an aluminum driver and the Phillips #00 head.
    • You should now be able to simply take the WiFi bar off of the device.
Conclusie
Sean Yap
1.253 Reputatie
6 handleidingen geschreven
Cal Poly, Team 19-12, Maness Winter 2015 Lid van Cal Poly, Team 19-12, Maness Winter 2015
CPSU-MANESS-W15S19G12
5 Leden
8 handleidingen geschreven
Één opmerking
Re Kindle Voyage Wifi Antenna Replacement guide: I cannot find the WiFi antenna bar on your website to purchase a replacement. Do you sell it?
carol cooper - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 11
Altijd: 1,924
