Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
The battery, like most batteries, gives juice to the device. This guide will show you how to carefully remove it for troubleshooting purposes.
  1. Insert a plastic opening tool between the plastic panel shown on the device. Use the tool to pry the plastic away from the device.
    • Insert a plastic opening tool between the plastic panel shown on the device.
    • Use the tool to pry the plastic away from the device.
    • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
  2. Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture.  For reassembly, note that the top two and bottom two screws are different sizes.
    • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
  3. Once the screws are removed, the back panel can slide off the device. Once the screws are removed, the back panel can slide off the device. Once the screws are removed, the back panel can slide off the device.
    • Once the screws are removed, the back panel can slide off the device.
    Why is step 4 needed? The magnetic component doesn’t appear to be in the way of the battery replacement. Is the magnetic component just sitting on the posts (without screws attaching)? Will any magnet work to remove it? Is there any electrical connection to this component?
    John - Antwoord
    There is no electrical connection, it is just sitting there. It should be removed so that it doesn’t fall out during the rest of the repair.
    Merlin04 - Antwoord
    I’ve tackled apparently more complicated jobs on iMac, MacBook and iPhone, but this one has defeated me! I can’t complete step 3 the panel simply will not slide off.
    Graham Miles - Antwoord
    Correction, tried some more. After one and a half hours of struggling I finally managed to slide the cover off. Now tht it’s been done once, it slides on and off easily.Just putting this here in case others have the same problem - persevere. In principle the job’s an easy one.
  4. Remove the magnetic component with the magnetic head of the aluminum driver. Remove the magnetic component with the magnetic head of the aluminum driver.
    • Remove the magnetic component with the magnetic head of the aluminum driver.
    This instruction confused me. There is a component above the battery. It’s not held there by anything (no adhesive or fasteners), so you can just take it off. They’re saying to use anything magnetic to pick it up, but you can just use your fingers.
    moec - Antwoord
  5. Use a plastic card to pry the battery away from the device. Gently un-clip the battery plug from the device and remove the battery.
    • Use a plastic card to pry the battery away from the device.
    • Gently un-clip the battery plug from the device and remove the battery.
    The battery in mine was VERY firmly stuck with adhesive. I had to use a lot of force to remove it, and the battery bent significantly.
    Patrick Cohen (ig88b) - Antwoord
    where did you buy a battery?
    thanks
    baggins - Antwoord
    Battery is now available from iFixit. See link on this page.
    moec - Antwoord
Conclusie
16 andere personen hebben deze handleiding voltooid.
Sean Yap
1.000 Reputatie
6 handleidingen geschreven
Cal Poly, Team 19-12, Maness Winter 2015 Lid van Cal Poly, Team 19-12, Maness Winter 2015
CPSU-MANESS-W15S19G12
5 Leden
Where can I buy a replacement buttery for my kindle voyage?
hegi88 - Antwoord
Where to find a replacement battery for kindle voyage 3G please if any one knows
Himadri Endow - Antwoord
Bump. Cannot seem to procure a new battery for the Kindle Voyage. Nice to know how to replace the old one; just need something to replace it WITH! Thanks for any hints on finding one. Battery model number is: MC-305070, 3.8V 1320mAh/5.01Wh, P/N 58-000056
larryg - Antwoord
Any advance on where one can find a replacement battery for the Kindle Journal?
Charles WRIGHT - Antwoord
Still looking for a source for this battery.
Neil Hall - Antwoord
For those looking for the battery, I’ve found them on both amazon and eBay by searching “305070 battery”
Amy Galvan - Antwoord
what does the battery symbol with an “!” in it mean?
book Lover - Antwoord
For those looking for the battery, iFixit now sells it. Inexpensive and good quality, arrived quickly. See link on this page.
moec - Antwoord
Well, good news is this was pretty easy. Bad news is my device still shows a battery ! icon. So something else is wrong. If anyone has any suggestions, I am interested in hearing….
moec - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 56
Afgelopen 30 dagen: 174
Altijd: 13,241
