Inleiding
Removing the Kindle Voyage back panel is a necessity for replacing all the other parts of the device.
Wat je nodig hebt
Insert a plastic opening tool between the plastic panel shown on the device.
Use the tool to pry the plastic away from the device.
3 andere personen hebben deze handleiding voltooid.
4 opmerkingen
I have the same problem. It would be very helpful to get a tip here.
I 'm having the same problem with Hanna:
I' having trouble getting the last two clips to snap back together on the top of the device. I'm pinching them together at the top, but nothing happens. It doesn't seem like it should be this difficult. What do you advise? Thanks!
Years later, but I just replaced the battery in mine and figured this out. You have to align the top clips first (and may have to lightly pry them open before you do that). Then bow the piece of plastic slightly and get the bottom clips in.
