Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
If you have damage to the front plate,screen or need access to the screws behind the plate, this guide will tell you how to do so.
Wat je nodig hebt
Use the plastic opening tool to undo the ten plastic clips around the back panel of the Kindle.
Remove the six 4 mm screws in order to access the front plate. Use a Phillips #00 screwdriver.
Use a plastic opening tool to pry the top three sides of the bezel. Since there is glue under the bezel, gently pivot the face at the bottom off the Kindle and slide the clips out.
4 andere personen hebben deze handleiding voltooid.
