Ga door naar hoofdinhoud
Kindle Touch Bezel Replacement
Wat je nodig hebt
  1. Kindle Touch Bezel Replacement, Back Cover: stap 1, afbeelding 1 van 3 Kindle Touch Bezel Replacement, Back Cover: stap 1, afbeelding 2 van 3 Kindle Touch Bezel Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Use the plastic opening tool to undo the ten plastic clips around the back panel of the Kindle.
    Wear work gloves as the tool can easily slip and stab you in the hand.
    BRUCE - Antwoord
    The clips aren't all the same; the side clips are slide-locks rather than press-locks.
    Use the Opening Tool to unclip the clips along the bottom edge. This will allow the lid to slide towards the top, releasing the side clips and allowing the lid to be lifted off.
    When reassembling, slide the lid upwards while pressing the sides to re-engage the side clips, then press the bottom edge to lock it into place.
    jimf - Antwoord
  2. Kindle Touch Bezel Replacement: stap 2, afbeelding 1 van 2 Kindle Touch Bezel Replacement: stap 2, afbeelding 2 van 2
    • Gently lift the bottom and slide the panel off.
    There are four tabs on each side.The two nearest the top are open at the top, hence they slide out (back towards the power connector end.
    This is important in the reassembly stage:
    1. Align the back cover about 0.75 cm away from the top
    2. Hold the top half of the cover flat against the unit, and flex the cover away from the case a little at the bottom
    3. Slide the top and the first two clips parallel to the case
    4. snap the remaining bottom clips in place
    John Haywood - Antwoord
  3. Kindle Touch Bezel Replacement, Bezel: stap 3, afbeelding 1 van 2 Kindle Touch Bezel Replacement, Bezel: stap 3, afbeelding 2 van 2
    • Using a Phillips #00 screwdriver, remove the six 4 mm screws to access the front plate.
  4. Kindle Touch Bezel Replacement: stap 4, afbeelding 1 van 3 Kindle Touch Bezel Replacement: stap 4, afbeelding 2 van 3 Kindle Touch Bezel Replacement: stap 4, afbeelding 3 van 3
    • Use the plastic opening tool to pry the bezel from the top and sides
    • The bottom of the bezel will be glued, so be careful when sliding the clips out.
    • The clips can be easily bent, so do not try to force them out. If you do bend some, they can be bent back.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Jerome Narine
221 Reputatie
1 Handleiding geschreven
USF Tampa, Team 19-5, Blackwell Winter 2015 Lid van USF Tampa, Team 19-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G5
3 Leden
8 handleidingen geschreven
Één opmerking
I want to paint The bezel white. Will it come back and fit perfectly after the removal I have to make?
denianyc - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 17
Altijd: 3,002
