Ga door naar hoofdinhoud
Kindle Paperwhite 1st Generation Case Replacement
Wat je nodig hebt
  1. Kindle Paperwhite 1st Generation Case Replacement, Case: stap 1, afbeelding 1 van 2 Kindle Paperwhite 1st Generation Case Replacement, Case: stap 1, afbeelding 2 van 2
    • Using a spudger or plastic opening tool, gently pry the bezel from the screen. It is easier to start in the corners and work your way around the bezel.
    • Do not insert the spudger too far under the bezel; it could easily damage the screen.
  2. Kindle Paperwhite 1st Generation Case Replacement: stap 2, afbeelding 1 van 3 Kindle Paperwhite 1st Generation Case Replacement: stap 2, afbeelding 2 van 3 Kindle Paperwhite 1st Generation Case Replacement: stap 2, afbeelding 3 van 3
    • Remove the eleven 3.0 mm Phillips screws surrounding the midframe.
    • At the top of the display, a strip of black tape covers one screw.
  3. Kindle Paperwhite 1st Generation Case Replacement: stap 3, afbeelding 1 van 1
    • Lift the midframe out of the case.
    • If the midframe is stuck, slide it to the left first, and then lift it out.
Conclusie
Anthony Nahal
60 Reputatie
3 handleidingen geschreven
Cal Poly, Team 3-33, Amido Winter 2013 Lid van Cal Poly, Team 3-33, Amido Winter 2013
CPSU-AMIDO-W13S3G33
4 Leden
17 handleidingen geschreven
2 opmerkingen
Thanks for the guide but do you know anywhere can we get a replacement case?
jerryw - Antwoord
4 years too late but I found this
Pao-Tang Kao - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 101
Altijd: 9,417
