Ga door naar hoofdinhoud
Inleiding
Is your Kindle Fire HDX 7” tablet refusing to get louder or quitter at the push of its buttons? The ribbon cable or buttons may be broken.
Follow this guide to replace them yourself!
  1. Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet. The adhesive is strong and may require an iOpener, or heat gun, to soften. The adhesive is strong and may require an iOpener, or heat gun, to soften.
    • Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
    • The adhesive is strong and may require an iOpener, or heat gun, to soften.
  2. Remove the speaker bezel.
    • Remove the speaker bezel.
  3. Remove the six pink 3mm T3 Torx screws from the back case.
    • Remove the six pink 3mm T3 Torx screws from the back case.
  4. Wedge opening picks around the perimeter between the display and back case. Work the opening picks around the perimeter until the two halves disengage from each other.
    • Wedge opening picks around the perimeter between the display and back case.
    • Work the opening picks around the perimeter until the two halves disengage from each other.
    • Don't completely separate as the display ribbon cable still connects the two.
  5. Use the flat end of a spudger to pry up and disconnect the rear panel press-fit connector from the motherboard.
    • Use the flat end of a spudger to pry up and disconnect the rear panel press-fit connector from the motherboard.
    • There may be a glue strip between the battery and the outside case. Gently pry the case open and use the flat end of a spudger to separate the glue strip.
  6. Remove the two 2.1mm T5 Torx screws from the volume button retaining bracket.
    • Remove the two 2.1mm T5 Torx screws from the volume button retaining bracket.
  7. Pry up the volume button ribbon cable from the rear panel with the flat end of a spudger. Pull up on the volume button ribbon cable to remove it from the tablet.
    • Pry up the volume button ribbon cable from the rear panel with the flat end of a spudger.
    • Pull up on the volume button ribbon cable to remove it from the tablet.
  8. Remove the volume button from the rear panel.
    • Remove the volume button from the rear panel.
Conclusie
Blake Klein
62.664 Reputatie
56 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 39
Altijd: 839
