Ga door naar hoofdinhoud
Kindle Fire HDX 7" Power Button Replacement
Wat je nodig hebt
  1. Kindle Fire HDX 7" Power Button Replacement, Speaker Bezel: stap 1, afbeelding 1 van 3 Kindle Fire HDX 7" Power Button Replacement, Speaker Bezel: stap 1, afbeelding 2 van 3 Kindle Fire HDX 7" Power Button Replacement, Speaker Bezel: stap 1, afbeelding 3 van 3
    • Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
    • The adhesive is strong and may require an iOpener, or heat gun, to soften.
  2. Kindle Fire HDX 7" Power Button Replacement: stap 2, afbeelding 1 van 1
    • Remove the speaker bezel.
  3. Kindle Fire HDX 7" Power Button Replacement, Rear Panel: stap 3, afbeelding 1 van 1
    • Remove the six pink 3mm T3 Torx screws from the back case.
  4. Kindle Fire HDX 7" Power Button Replacement: stap 4, afbeelding 1 van 2 Kindle Fire HDX 7" Power Button Replacement: stap 4, afbeelding 2 van 2
    • Wedge opening picks around the perimeter between the display and back case.
    • Work the opening picks around the perimeter until the two halves disengage from each other.
    • Don't completely separate as the display ribbon cable still connects the two.
  5. Kindle Fire HDX 7" Power Button Replacement: stap 5, afbeelding 1 van 1
    • Use the flat end of a spudger to pry up and disconnect the rear panel press-fit connector from the motherboard.
    • There may be a glue strip between the battery and the outside case. Gently pry the case open and use the flat end of a spudger to separate the glue strip.
  6. Kindle Fire HDX 7" Power Button Replacement, Micro USB Charging Port: stap 7, afbeelding 1 van 1
    • Remove the four 2.3mm T5 Torx screws from the micro USB port and power button assembly.
  7. Kindle Fire HDX 7" Power Button Replacement: stap 8, afbeelding 1 van 2 Kindle Fire HDX 7" Power Button Replacement: stap 8, afbeelding 2 van 2
    • Pry up the ribbon cable from the rear panel with the flat end of a spudger.
    • Remove the micro USB port and power button ribbon cable.
  8. Kindle Fire HDX 7" Power Button Replacement, Power Button: stap 9, afbeelding 1 van 1
    • Remove the power button from the rear panel.
Conclusie
Blake Klein
70.531 Reputatie
50 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 751
