Inleiding
Use this guide to remove the battery from the back of the Kindle Fire HD 8.9".
Onderdelen
Remove the SIM card tray (if present in your model).
Insert a large plastic opening tool next to the Kindle's headphone jack.
Move the plastic opening tool evenly around the Kindle, separating the two halves.
Remove the following sixteen screws from the metal midframe on the rear of the device:
One 3 mm Phillips screw from each corner
Four 3 mm Phillips screws surrounding the ports
Eight 3 mm Phillips screws from the body of the midframe
Lift up on the silver ends of the black flex cable that lays across the battery.
Gently pull the black flex cable from the battery.
Starting at the outside edge of the battery, use the flat edge of a spudger to separate the battery from the rear of the device.
Move the spudger along each side of the battery, prying upwards with even pressure.
As the adhesive releases, push the spudger further underneath the battery.
Once half of the battery is detached, pry the other half in the same manner.
Remove the battery assembly from the Kindle.
16 andere personen hebben deze handleiding voltooid.
5 Opmerkingen
Thank you for the detailed repair guide! You can find a brand new replacement battery here: http://www.mpfproducts.com/products.php?...
This repair only takes about 20 minutes. Thanks!
check out the CS Technology version http://bestbattery.biz/Amazon_Kindle-Fir...
