Inleiding
Remove the back case from your Kindle Fire to access its internal components.
Wat je nodig hebt
Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
It is helpful to pry the bottom of the Kindle Fire away (and out from the side) from the top part. Exerting too much force attempting to split the two without pulling away can cause the tabs on the inside to crack.
Once you have freed all the plastic clips, pull the back case off the Kindle Fire.
Order placed
Mine has another plastic pc over the m.etal plate
14 andere personen hebben deze handleiding voltooid.
3 opmerkingen
Simple to follow instructions .
where to buy the base panel for my kindle fire 7 tablet
Where can I buy a battery for my kindle fire
nannyto2 - Antwoord
Try EBay or Amazon. make sure you get the right battery for your Kindle , one is for a Kindle HD and the older version........both are 7 ".
vvenona1954 - Antwoord
Remember to remove any sd card first!!! Snapped mine in half.
lucy_lady_bug - Antwoord
I have the first kindle that came out and it doesn't have the same setup how can I open the back of my kindle?
Kris Sanders - Antwoord
