Ga door naar hoofdinhoud
Kindle 7th Generation Front Panel Replacement
Wat je nodig hebt
  1. Kindle 7th Generation Front Panel Replacement, Front Panel: stap 1, afbeelding 1 van 2 Kindle 7th Generation Front Panel Replacement, Front Panel: stap 1, afbeelding 2 van 2
    • Power off your Kindle before beginning disassembly.
    • At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
    • Run the tool along the seams to pry open the front panel.
  2. Kindle 7th Generation Front Panel Replacement: stap 2, afbeelding 1 van 1
    • Peel the front panel off to remove it from the Kindle.
    • If this is the first time the front panel has been removed, the adhesive may require a significant amount of force to undo.
    • To prevent damaging the front panel, peel the panel from the corners towards the middle of the Kindle.
    • When reassembling your device, if you are replacing the front panel, additional adhesive may be required.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Abby Roulier
966 Reputatie
3 handleidingen geschreven
Cal Poly, Team 6-28, Amido Winter 2015 Lid van Cal Poly, Team 6-28, Amido Winter 2015
CPSU-AMIDO-W15S6G28
4 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 55
Altijd: 4,982
