Ga door naar hoofdinhoud
Kindle 7th Generation Battery Replacement
Wat je nodig hebt
  1. Kindle 7th Generation Battery Replacement, Front Panel: stap 1, afbeelding 1 van 2 Kindle 7th Generation Battery Replacement, Front Panel: stap 1, afbeelding 2 van 2
    • Power off your Kindle before beginning disassembly.
    • At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
    • Run the tool along the seams to pry open the front panel.
    Vraag FixBot
    Voeg opmerking toe
  2. Kindle 7th Generation Battery Replacement: stap 2, afbeelding 1 van 1
    • Peel the front panel off to remove it from the Kindle.
    • If this is the first time the front panel has been removed, the adhesive may require a significant amount of force to undo.
    • To prevent damaging the front panel, peel the panel from the corners towards the middle of the Kindle.
    • When reassembling your device, if you are replacing the front panel, additional adhesive may be required.
    Vraag FixBot
    Voeg opmerking toe
  3. Kindle 7th Generation Battery Replacement, Back Panel: stap 3, afbeelding 1 van 2 Kindle 7th Generation Battery Replacement, Back Panel: stap 3, afbeelding 2 van 2
    • Remove the ten 5.0 mm T5 Torx screws.
    • A magnetized screw mat can help you keep track of your screws.
    Vraag FixBot
    Voeg opmerking toe
  4. Kindle 7th Generation Battery Replacement: stap 4, afbeelding 1 van 1
    • Working evenly along the corners and edges, separate the internal contents from the back panel.
    • There are many clips securing the screen to the back panel. Force will be required to remove the back, but you should never feel that the Kindle may break.
    Vraag FixBot
    Voeg opmerking toe
  5. Kindle 7th Generation Battery Replacement, Battery: stap 5, afbeelding 1 van 1
    • Flip the Kindle over, exposing the battery and motherboard.
    Vraag FixBot
    Voeg opmerking toe
  6. Kindle 7th Generation Battery Replacement: stap 6, afbeelding 1 van 2 Kindle 7th Generation Battery Replacement: stap 6, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use the blunted precision tweezers to pinch the ends of the clip securing the battery cord to the motherboard.
    • Gently slide the cord from the motherboard connection.
    Vraag FixBot
    Voeg opmerking toe
  7. Kindle 7th Generation Battery Replacement: stap 7, afbeelding 1 van 3 Kindle 7th Generation Battery Replacement: stap 7, afbeelding 2 van 3 Kindle 7th Generation Battery Replacement: stap 7, afbeelding 3 van 3
    • Use the plastic opening tool to pry the battery from the backside of the screen.
    • Set the battery aside.
    • The battery has excessive adhesive so this may take some extra effort. See picture of battery deformed by prying tool during removal.
    • If replacing your battery, safely dispose of your damaged battery and use adhesive to insert the new battery.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
35 andere personen hebben deze handleiding voltooid.
Abby Roulier
1.167 Reputatie
3 handleidingen geschreven
Cal Poly, Team 6-28, Amido Winter 2015 Lid van Cal Poly, Team 6-28, Amido Winter 2015
CPSU-AMIDO-W15S6G28
4 Leden
26 handleidingen geschreven
27Gids Commentaar
Where can I purchase the battery?
Boon - Antwoord Deel
@boonspot right here on this site: Kindle 7 (2014) Battery
Nathan T - Antwoord Deel
Fairly easy to do. Saves a lot of money compared to buying a whole new Kindle :) Thank you for this! A note: I've never seen batteries as...soft as these. Take care when using the removal tool. I could be easy to puncture the battery which could cause a big mess and possibly injury.
Joshua - Antwoord Deel
My old battery got seriously deformed during removal, but didn't puncture or tear. I added a picture to the guide, so that hopefully the next person is not as alarmed as I was :)
Where do I get a new battery from please?
Tracy Armstrong - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 41
Afgelopen 7 dagen: 206
Afgelopen 30 dagen: 965
Altijd: 64,801
