Ga door naar hoofdinhoud
Kindle 7th Generation Back Panel Replacement
Wat je nodig hebt
  1. Kindle 7th Generation Back Panel Replacement, Front Panel: stap 1, afbeelding 1 van 2 Kindle 7th Generation Back Panel Replacement, Front Panel: stap 1, afbeelding 2 van 2
    • Power off your Kindle before beginning disassembly.
    • At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
    • Run the tool along the seams to pry open the front panel.
  2. Kindle 7th Generation Back Panel Replacement: stap 2, afbeelding 1 van 1
    • Peel the front panel off to remove it from the Kindle.
    • If this is the first time the front panel has been removed, the adhesive may require a significant amount of force to undo.
    • To prevent damaging the front panel, peel the panel from the corners towards the middle of the Kindle.
    • When reassembling your device, if you are replacing the front panel, additional adhesive may be required.
  3. Kindle 7th Generation Back Panel Replacement, Back Panel: stap 3, afbeelding 1 van 2 Kindle 7th Generation Back Panel Replacement, Back Panel: stap 3, afbeelding 2 van 2
    • Remove the ten 5.0 mm T5 Torx screws.
    • A magnetized screw mat can help you keep track of your screws.
  4. Kindle 7th Generation Back Panel Replacement: stap 4, afbeelding 1 van 1
    • Working evenly along the corners and edges, separate the internal contents from the back panel.
    • There are many clips securing the screen to the back panel. Force will be required to remove the back, but you should never feel that the Kindle may break.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Abby Roulier
966 Reputatie
3 handleidingen geschreven
Cal Poly, Team 6-28, Amido Winter 2015 Lid van Cal Poly, Team 6-28, Amido Winter 2015
CPSU-AMIDO-W15S6G28
4 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 53
Altijd: 4,841
