Ga door naar hoofdinhoud
Kindle 2 Wireless Card Replacement
Wat je nodig hebt
  1. Kindle 2 Wireless Card Replacement, Battery: stap 1, afbeelding 1 van 3 Kindle 2 Wireless Card Replacement, Battery: stap 1, afbeelding 2 van 3 Kindle 2 Wireless Card Replacement, Battery: stap 1, afbeelding 3 van 3
    • Lay the Kindle face down on a soft cloth to protect its screen.
    • Wedge the plastic opening tool in the small opening between the grey plastic and the metal casing.
    • Move the plastic opening tool across the opening while pressing down to separate the grey plastic from the metal casing.
    • Slide the gray plastic top piece away from the Kindle's metal casing.
    • Once the gray plastic top piece is detached from the metal back cover, remove it.
  2. Kindle 2 Wireless Card Replacement: stap 2, afbeelding 1 van 2 Kindle 2 Wireless Card Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the two 4 mm screws from the metal casing.
  3. Kindle 2 Wireless Card Replacement: stap 3, afbeelding 1 van 2 Kindle 2 Wireless Card Replacement: stap 3, afbeelding 2 van 2
    • Use the plastic opening tool to push down and pry towards the metal casing to release each of the three clips that hold the metal case in place.
    • Remove the metal casing.
    • The volume control button rests in a slot on the side of the Kindle. When the metal casing is removed, the volume control button may fall out. When reassembling, place the volume control button back into its slot.
  4. Kindle 2 Wireless Card Replacement: stap 4, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws that hold the battery in place.
    • The battery should be removed before continuing with the rest of this guide to prevent harm to you and the device.
  5. Kindle 2 Wireless Card Replacement: stap 5, afbeelding 1 van 2 Kindle 2 Wireless Card Replacement: stap 5, afbeelding 2 van 2
    • Pry upward under the black tab with the spudger to dislodge the battery.
    • Use your fingers to lift the battery out of the device.
  6. Kindle 2 Wireless Card Replacement, Wireless Card: stap 6, afbeelding 1 van 1
    • Rotate the Kindle 180 degrees. Locate the wireless card with the AnyData logo on the top left and the FCC symbol on the right.
    • Use a Phillips #00 screwdriver to remove the two 2mm screws from the wireless card.
  7. Kindle 2 Wireless Card Replacement: stap 7, afbeelding 1 van 1
    • Use the plastic opening tool to wedge underneath the connection and gently pop off the wire cap.
  8. Kindle 2 Wireless Card Replacement: stap 8, afbeelding 1 van 2 Kindle 2 Wireless Card Replacement: stap 8, afbeelding 2 van 2
    • Use your fingers to lift the left end of the wireless card.
    • Pull the card out of the slot.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Dayna Scott
985 Reputatie
5 handleidingen geschreven
Cal Poly, Team 12-32, Amido Spring 2013 Lid van Cal Poly, Team 12-32, Amido Spring 2013
CPSU-AMIDO-S13S12G32
4 Leden
14 handleidingen geschreven
1Gids Commentaar
The Kindle 2 in the US only used 2G/3G. Did some other models have a Wi-Fi card instead? It would be cool to swap them out if so to restore functionality.
Navarre - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 42
Altijd: 2,177
