Ga door naar hoofdinhoud
Kindle 1st Generation ON/OFF Power and Wifi Switches Replacement
Wat je nodig hebt
  1. Kindle 1st Generation ON/OFF Power and Wifi Switches Replacement, Battery: stap 1, afbeelding 1 van 1
    • Slide the grey plastic cover laterally off the back of the device.
  2. Kindle 1st Generation ON/OFF Power and Wifi Switches Replacement: stap 2, afbeelding 1 van 2 Kindle 1st Generation ON/OFF Power and Wifi Switches Replacement: stap 2, afbeelding 2 van 2
    • Use a plastic opening tool to lift the battery on the side closest to the edge of the device.
    • Unplug the battery from the device by pinching the white connector and pulling.
    • Do not yank the battery or try to disconnect the battery by pulling the wires.
  3. Kindle 1st Generation ON/OFF Power and Wifi Switches Replacement, ON/OFF Power and Wifi Switches: stap 3, afbeelding 1 van 1
    • Unscrew eight (8) Phillips #00 screws (3 mm).
  4. Kindle 1st Generation ON/OFF Power and Wifi Switches Replacement: stap 4, afbeelding 1 van 2 Kindle 1st Generation ON/OFF Power and Wifi Switches Replacement: stap 4, afbeelding 2 van 2
    • Start at one side of the device. Use a soft plastic prying tool to separate the casing of the device. Slowly work your way around the entire device.
    • Avoid prying between the buttons and the device. This could cause damage to the buttons.
  5. Kindle 1st Generation ON/OFF Power and Wifi Switches Replacement: stap 5, afbeelding 1 van 2 Kindle 1st Generation ON/OFF Power and Wifi Switches Replacement: stap 5, afbeelding 2 van 2
    • Unscrew the two (2) Phillips #00 screws (3 mm) which fasten the metal casing shield.
    • Slowly remove the metal casing shield by lifting it and carefully peeling up the tape.
  6. Kindle 1st Generation ON/OFF Power and Wifi Switches Replacement: stap 6, afbeelding 1 van 1
    • Remove the two (2) Phillips #00 screws (3 mm) which fasten the ON/OFF Power and Wifi Switches to the device.
  7. Kindle 1st Generation ON/OFF Power and Wifi Switches Replacement: stap 7, afbeelding 1 van 2 Kindle 1st Generation ON/OFF Power and Wifi Switches Replacement: stap 7, afbeelding 2 van 2
    • Lift the flap attaching the blue and white ribbon cable to the motherboard by lifting it vertically with the pointed-end of the spudger.
    • The flap is connected via a hinge. Once you lift the flap, it will stay up and the cable will be lose. Remember to snap it back down during reassembly.
    • Carefully lift the ON/OFF Power and Wifi Switch vertically from the device motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 1,980
