Ga door naar hoofdinhoud
Kindle 1st Generation Keyboard/Buttons Replacement
Wat je nodig hebt
  1. Kindle 1st Generation Keyboard/Buttons Replacement, Battery: stap 1, afbeelding 1 van 1
    • Slide the grey plastic cover laterally off the back of the device.
  2. Kindle 1st Generation Keyboard/Buttons Replacement: stap 2, afbeelding 1 van 2 Kindle 1st Generation Keyboard/Buttons Replacement: stap 2, afbeelding 2 van 2
    • Use a plastic opening tool to lift the battery on the side closest to the edge of the device.
    • Unplug the battery from the device by pinching the white connector and pulling.
    • Do not yank the battery or try to disconnect the battery by pulling the wires.
  3. Kindle 1st Generation Keyboard/Buttons Replacement, SD Card Reader: stap 3, afbeelding 1 van 1
    • Unscrew eight (8) Phillips #00 screws (3 mm).
  4. Kindle 1st Generation Keyboard/Buttons Replacement: stap 4, afbeelding 1 van 2 Kindle 1st Generation Keyboard/Buttons Replacement: stap 4, afbeelding 2 van 2
    • Start at one side of the device. Use a plastic opening tool to separate the casing of the device. Slowly work your way around the entire device.
    • Avoid prying between the buttons and the device. This could cause damage to the buttons.
  5. Kindle 1st Generation Keyboard/Buttons Replacement: stap 5, afbeelding 1 van 2 Kindle 1st Generation Keyboard/Buttons Replacement: stap 5, afbeelding 2 van 2
    • Unscrew the two (2) Phillips #00 screws (3 mm) which fasten the metal casing shield.
    • Slowly remove the metal casing shield by lifting it and carefully peeling up the tape.
  6. Kindle 1st Generation Keyboard/Buttons Replacement: stap 6, afbeelding 1 van 1
    • Remove the four (4) Phillips #00 screws (3 mm) which fasten the SD Card Reader.
  7. Kindle 1st Generation Keyboard/Buttons Replacement: stap 7, afbeelding 1 van 2 Kindle 1st Generation Keyboard/Buttons Replacement: stap 7, afbeelding 2 van 2
    • Lift the flap attaching the blue and white ribbon cable to the motherboard by lifting it vertically with a spudger.
    • The flap is connected via a hinge. Once you lift the flap, it will stay up and the cable will be lose. Remember to snap it back down during reassembly.
    • Carefully lift the SD Card Reader vertically from the motherboard.
  8. Kindle 1st Generation Keyboard/Buttons Replacement, Page Turner Keys: stap 8, afbeelding 1 van 1
    • Remove the two (2) Phillips #00 screws (3 mm) connecting the ON/OFF Power and Wifi Switches.
  9. Kindle 1st Generation Keyboard/Buttons Replacement: stap 9, afbeelding 1 van 2 Kindle 1st Generation Keyboard/Buttons Replacement: stap 9, afbeelding 2 van 2
    • Lift the flap attaching the blue and white ribbon cable to the motherboard by lifting it vertically with the pointed-end of the spudger.
    • Carefully lift the ON/OFF Power and Wifi Switches vertically from the device motherboard.
  10. Kindle 1st Generation Keyboard/Buttons Replacement: stap 10, afbeelding 1 van 2 Kindle 1st Generation Keyboard/Buttons Replacement: stap 10, afbeelding 2 van 2
    • Use a spudger to remove the Wifi antenna from the device by carefully prying it up off the casing.
    • The Wifi antenna is attached to the device by a mild adhesive. Once the antenna is free from the adhesive, set the antenna off to the side.
    • Do not try to detach the antenna from the motherboard.
  11. Kindle 1st Generation Keyboard/Buttons Replacement: stap 11, afbeelding 1 van 3 Kindle 1st Generation Keyboard/Buttons Replacement: stap 11, afbeelding 2 van 3 Kindle 1st Generation Keyboard/Buttons Replacement: stap 11, afbeelding 3 van 3
    • Unscrew the two (2) Phillips #00 screws (3 mm) attaching the scroll bar.
    • Use a spudger to lift the flap vertically in the second image to release the scroll bar from the motherboard.
    • Do not pull the scroll bar off the device. Simply flip it around so it is out of the way for further disassembly, as seen in the third image.
  12. Kindle 1st Generation Keyboard/Buttons Replacement: stap 12, afbeelding 1 van 3 Kindle 1st Generation Keyboard/Buttons Replacement: stap 12, afbeelding 2 van 3 Kindle 1st Generation Keyboard/Buttons Replacement: stap 12, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Lift the flap attaching the blue and white ribbon cable to the motherboard by lifting it vertically with the spudger.
    • Lift the flap with the pointed-end of the spudger to detach the ribbon cable indicated in the second image.
    • The flaps are connected via a hinge. Once you lift the flap, it will stay up and the cable will be lose. Remember to snap it back down during reassembly.
    • Use tweezers to pull the ribbon cable in the third image laterally to detach it.
  13. Kindle 1st Generation Keyboard/Buttons Replacement: stap 13, afbeelding 1 van 1
    • Detach the cable by pulling laterally with tweezers or your fingertips. Do this by grasping the edges of the white connector and pulling laterally.
    • Grasp the end of the cable with tweezers or your fingertips and pull upwards to detach it from the motherboard.
    • Do not grasp either cable by the wires and attempt to pull them.
  14. Kindle 1st Generation Keyboard/Buttons Replacement: stap 14, afbeelding 1 van 3 Kindle 1st Generation Keyboard/Buttons Replacement: stap 14, afbeelding 2 van 3 Kindle 1st Generation Keyboard/Buttons Replacement: stap 14, afbeelding 3 van 3
    • Remove the two (2) Phillips #00 screws (3 mm) which attach the motherboard to the front casing.
    • Carefully lift the motherboard off.
    • The piece marked in the third image may be loose and fall out freely. If it does not fall off, use your fingers or a plastic opening tool to snap it off. Make sure to place it under the motherboard during reassembly, as found in the image.
  15. Kindle 1st Generation Keyboard/Buttons Replacement: stap 15, afbeelding 1 van 1
    • Remove the seven (7) Phillips #00 screws (3 mm) remaining on the frame.
    • The orange-marked metal piece is only held down by a screw and will become loose. Make sure to re-position it during assembly.
  16. Kindle 1st Generation Keyboard/Buttons Replacement: stap 16, afbeelding 1 van 2 Kindle 1st Generation Keyboard/Buttons Replacement: stap 16, afbeelding 2 van 2
    • Press down firmly on the two white tabs, behind the large 'NEXT PAGE' button with the spudger. This will unsnap the front casing from the rest of the device.
    • The front case will begin to come loose. Do not try to pull it off.
    • Slide out the large 'NEXT PAGE' button laterally away from the keyboard.
  17. Kindle 1st Generation Keyboard/Buttons Replacement: stap 17, afbeelding 1 van 2 Kindle 1st Generation Keyboard/Buttons Replacement: stap 17, afbeelding 2 van 2
    • Slightly lift the top corner of the panel.
    • Slide the 'PREV PAGE' button out laterally towards the top corner.
  18. Kindle 1st Generation Keyboard/Buttons Replacement: stap 18, afbeelding 1 van 2 Kindle 1st Generation Keyboard/Buttons Replacement: stap 18, afbeelding 2 van 2
    • Slide out the small 'NEXT PAGE' button laterally towards the keyboard.
  19. Kindle 1st Generation Keyboard/Buttons Replacement: stap 19, afbeelding 1 van 2 Kindle 1st Generation Keyboard/Buttons Replacement: stap 19, afbeelding 2 van 2
    • Slide out the small 'BACK' button laterally towards the keyboard.
  20. Kindle 1st Generation Keyboard/Buttons Replacement, Keyboard/Buttons: stap 20, afbeelding 1 van 2 Kindle 1st Generation Keyboard/Buttons Replacement, Keyboard/Buttons: stap 20, afbeelding 2 van 2
    • The keyboard and the blue and white ribbon cable will slide out horizontally from behind the frame.
    • The rubber key pads will slide out from behind the frame.
Conclusie
1Gids Commentaar
Where do you get a replacement controller wheel/button. This is what failed on my 1st gen kindle.
Joyce stevenson - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 49
Altijd: 2,069
