Ga door naar hoofdinhoud
Kihno Kit Album Battery Replacement
Wat je nodig hebt
  1. Kihno Kit Album Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Kihno Kit Album Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Insert a spudger into the gap and pull downwards, so the top lifts up.
  2. Kihno Kit Album Battery Replacement: stap 2, afbeelding 1 van 2 Kihno Kit Album Battery Replacement: stap 2, afbeelding 2 van 2
    • Pull out the wired component from the Kihno for better access.
    • Remove the old battery by pulling outward towards yourself, starting from the top.
  3. Kihno Kit Album Battery Replacement: stap 3, afbeelding 1 van 1
    • Grab your new battery and place it where the old one was.
    • Angle the battery to where it is underneath the golden flap.
    • Push the rest of the battery down.
  4. Kihno Kit Album Battery Replacement: stap 4, afbeelding 1 van 1
    • Place the wired components back into the Kihno.
    • Ensure the white button is sticking from the outside through its designated hole.
  5. Kihno Kit Album Battery Replacement: stap 5, afbeelding 1 van 1
    • Using your fingers, push the top back into the Kihno.
Eindstreep
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 72
Altijd: 405
