Ga door naar hoofdinhoud
Kids Digital Watch Battery Replacement
Wat je nodig hebt
  1. Kids Digital Watch Battery Replacement, Remove Watch Bands: stap 1, afbeelding 1 van 2 Kids Digital Watch Battery Replacement, Remove Watch Bands: stap 1, afbeelding 2 van 2
    • Using a twisting and pulling motion, remove the straps from the watch.
  2. Kids Digital Watch Battery Replacement, Unscrew Backplate: stap 2, afbeelding 1 van 1
    • Remove the four (4) screws on the backside of the watch with the small Philips head screwdriver.
  3. Kids Digital Watch Battery Replacement, Remove Backplate: stap 3, afbeelding 1 van 1
    • Remove the backplate carefully using your hands.
  4. Kids Digital Watch Battery Replacement, Remove Circuit Protector Plate: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove using tweezers the circuit protector plate that is uncovered once the backplate is removed.
  5. Kids Digital Watch Battery Replacement, Removing Screw Near the Blue Component: stap 5, afbeelding 1 van 2 Kids Digital Watch Battery Replacement, Removing Screw Near the Blue Component: stap 5, afbeelding 2 van 2
    • With the tiny Philips head screwdriver, unscrew and remove the screw closest to the blue component.
  6. Kids Digital Watch Battery Replacement, Removing Screw Near the Yellow Component: stap 6, afbeelding 1 van 1
    • Now remove the screw on the other side of the battery near the yellow circuit component.
  7. Kids Digital Watch Battery Replacement, Remove the Battery Protector Plate: stap 7, afbeelding 1 van 2 Kids Digital Watch Battery Replacement, Remove the Battery Protector Plate: stap 7, afbeelding 2 van 2
    • Using tweezers carefully remove the battery protector plate.
  8. Kids Digital Watch Battery Replacement, Remove Battery: stap 8, afbeelding 1 van 1
    • Remove the old battery from your watch.
  9. Kids Digital Watch Battery Replacement, Insert New Battery: stap 9, afbeelding 1 van 1
    • Insert your new battery onto the circular component with your tweezers.
    • Ensure the positive and negative sides of your battery are oriented correctly.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Amelia S
194 Reputatie
1 Handleiding geschreven
ENGR_COMM_FIXERS Lid van ENGR_COMM_FIXERS
Community
3 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 66
Altijd: 710
