Ga door naar hoofdinhoud
Kid Motorz Xtreme Quad 12V Vehicle Battery Repair
Wat je nodig hebt
  1. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair, Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: stap 1, afbeelding 1 van 1
    • Remove the screw at the back of the seat.
    • Remove the seat from the device.
  2. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: stap 2, afbeelding 1 van 1
    • Remove the two screws along the bracket.
    • Remove the bracket.
  3. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: stap 3, afbeelding 1 van 1
    • Disconnect battery by gently pushing the tabs inwards and carefully unplugging it.
  4. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: stap 4, afbeelding 1 van 2 Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: stap 4, afbeelding 2 van 2
    • Remove the battery terminals and the battery.
  5. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: stap 5, afbeelding 1 van 1
    • Put safety gloves on before beginning to solder.
    • Take your solder and place it carefully on the terminal points of the battery (negative and positive).
  6. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: stap 6, afbeelding 1 van 1
    • Apply heat to the solder.
  7. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: stap 7, afbeelding 1 van 2 Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: stap 7, afbeelding 2 van 2
    • Position the wire onto the end piece and apply heat to the solder.
  8. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: stap 8, afbeelding 1 van 2 Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: stap 8, afbeelding 2 van 2
    • Put the battery back into its compartment.
    • Plug the battery back in.
  9. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: stap 9, afbeelding 1 van 1
    • Place the bracket back into its slot.
    • Screw the bracket screws back into place.
  10. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: stap 10, afbeelding 1 van 1
    • Place the seat back onto the device.
    • Screw the seat screw back into place.
  11. Kid Motorz Xtreme Quad 12V Vehicle Battery Repair: stap 11, afbeelding 1 van 1
    • Congratulations you are now ready to ride again!
Conclusie
The goal of this guide is to repair a battery terminal through solder and after completing the guide you should be able to apply what you learned to other projects and similar electronics
Één andere persoon heeft deze handleiding voltooid.
Yanal
243 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 10
Altijd: 162
