Ga door naar hoofdinhoud
Kid Galaxy Morphibians Explorer Battery Replacement
Wat je nodig hebt
  1. Kid Galaxy Morphibians Explorer Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • First, completely loosen the 9.6 mm Phillips #2 screw on top. There is a plastic washer that holds the screw to the top cover, so it will not need to be taken out.
  2. Kid Galaxy Morphibians Explorer Battery Replacement: stap 2, afbeelding 1 van 1
    • After the screw has been loosened, lift the cover off.
  3. Kid Galaxy Morphibians Explorer Battery Replacement: stap 3, afbeelding 1 van 1
    • Completely loosen the 9.6 mm Phillips #2 screw from the battery cover. Once again, there is a plastic washer to hold the screw to the cover.
  4. Kid Galaxy Morphibians Explorer Battery Replacement: stap 4, afbeelding 1 van 1
    • Lift the battery cover to gain access to the batteries.
    • Replace the 3 AA batteries and reverse the steps to put everything back together.
Conclusie
Rusbell Gonzalez
219 Reputatie
5 handleidingen geschreven
USF Tampa, Team 1-2, Hickman Fall 2014 Lid van USF Tampa, Team 1-2, Hickman Fall 2014
USFT-HICKMAN-F14S1G2
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 2,563
