Ga door naar hoofdinhoud
Kid Galaxy Morphibians Explorer Axle Replacement
Wat je nodig hebt
  1. Kid Galaxy Morphibians Explorer Axle Replacement, Axle: stap 1, afbeelding 1 van 1
    • Remove both 8.0 mm Phillips #1 screws, one for each wheel.
  2. Kid Galaxy Morphibians Explorer Axle Replacement: stap 2, afbeelding 1 van 1
    • Remove the wheels by pulling them away from the RC car.
  3. Kid Galaxy Morphibians Explorer Axle Replacement: stap 3, afbeelding 1 van 1
    • Make note of where each driving gear cover is placed. They only go in one way.
    • Remove the eight 8.0mm Phillips #00 screws, two screws for each wheel.
  4. Kid Galaxy Morphibians Explorer Axle Replacement: stap 4, afbeelding 1 van 1
    • Pry open the two gear covers on both sides.
  5. Kid Galaxy Morphibians Explorer Axle Replacement: stap 5, afbeelding 1 van 1
    • Pull the driving gears off the axles by sliding them off the axles and exposing both axles.
  6. Kid Galaxy Morphibians Explorer Axle Replacement: stap 6, afbeelding 1 van 1
    • Slide both axles from the internal axles guides within the car.
    • Reverse the steps to replace the axles.
Conclusie
Rusbell Gonzalez
219 Reputatie
5 handleidingen geschreven
USF Tampa, Team 1-2, Hickman Fall 2014 Lid van USF Tampa, Team 1-2, Hickman Fall 2014
USFT-HICKMAN-F14S1G2
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 292
