Ga door naar hoofdinhoud
Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly
Wat je nodig hebt
  1. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Remove the USB/Power Off Keyboard: stap 1, afbeelding 1 van 2 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Remove the USB/Power Off Keyboard: stap 1, afbeelding 2 van 2
    • Unplug the keyboard and toggle the leftmost switch to the 'Off" Position
    • For reference, the switches are located on the top of the keyboard.
  2. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Remove Keycaps: stap 2, afbeelding 1 van 3 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Remove Keycaps: stap 2, afbeelding 2 van 3 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Remove Keycaps: stap 2, afbeelding 3 van 3
    • Using a keycap puller, carefully remove the keys from the keyboard
    • NEVER attempt to remove the keyboard keys on any keyboard without a keycap puller or tool specialized to remove keyboard keys, not using the correct tool may damage the keys
  3. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Confirm switches are hot-swappable: stap 3, afbeelding 1 van 2 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Confirm switches are hot-swappable: stap 3, afbeelding 2 van 2
    • Check that your switches are hot-swappable. If they are not, trying to remove them will damage your keyboard.
    • The mechanical switches are NOT hot-swappable, and the colored stem is smaller and more oblong.
    • The optical switches are hot-swappable, and they have a larger colored stem which is mostly square.
  4. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Removal of Switches: stap 4, afbeelding 1 van 3 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Removal of Switches: stap 4, afbeelding 2 van 3 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Removal of Switches: stap 4, afbeelding 3 van 3
    • Use a switch puller to remove the switches.
    • If you have the included switch puller from Keychrone, it may be tough removing said switches.
    • Each switch has small tabs on the corners to grab and remove them. (The Included switch puller might require extra strength to remove)
  5. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Remove the Chassis Screws: stap 5, afbeelding 1 van 1
    • Use a # 1 philips drill bit to remove the 4 screws on the keyboard
  6. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Separate the Base and Top: stap 6, afbeelding 1 van 3 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Separate the Base and Top: stap 6, afbeelding 2 van 3 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Separate the Base and Top: stap 6, afbeelding 3 van 3
    • Use a spudger or another wedge tool to pry open the plastic base from the aluminum chassis.
    • Use caution when removing the base from the chassis as there are tabs that hold them together!
    • CAUTION: The battery is located on the plastic bottom. The battery is connected to the PCB located near the orange switches and USB
  7. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Disconnect the Battery: stap 7, afbeelding 1 van 2 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Disconnect the Battery: stap 7, afbeelding 2 van 2
    • Use tweezers to disconnect the battery from the PCB.
    • Use caution when removing the PCB! Pull away from the connector. Do not attempt to jiggle the cable as this may loosen/damage the connector
  8. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Remove the PCB: stap 8, afbeelding 1 van 1
    • Remove the 14 screws with a # 1 Philips screw driver bit
    • To remove the PCB from the aluminum frame, use a spudger to wedge it out.
  9. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Disassembly complete: stap 9, afbeelding 1 van 2 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Disassembly complete: stap 9, afbeelding 2 van 2
    • The PCB is now removed and able to work on.
    • When you reassemble the keyboard, make sure to put the orange toggles with the two nubs pointing towards the switch side of the aluminum frame.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Mike Villasenor
235 Reputatie
1 Handleiding geschreven
4 opmerkingen
Feel free to leave advice if you think I should change any steps. This is my first guide. Enjoy!
Mike Villasenor - Antwoord
Hi Mike,
Great job! Check out this article on creating guides–it has some great tips! Looking forward to reading your next one!
Amber Taus -
Do you know what size screws the keyboard uses?
Sam Jackson - Antwoord
Does anyone know where I can get a replacement battery for this keyboard?
Rakshak Raghavan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 50
Afgelopen 30 dagen: 194
Altijd: 6,854
