Inleiding
This guide will show you how to tear down the Keychron K3 keyboard. This is a complete teardown that involves removing the keys and keyboard frame to access the PCB. Thia guide is for the K3 with hot-swappable switches
Wat je nodig hebt
Unplug the keyboard and toggle the leftmost switch to the 'Off" Position
Check that your switches are hot-swappable. If they are not, trying to remove them will damage your keyboard.
The optical switches are hot-swappable, and they have a larger colored stem which is mostly square.
Use a switch puller to remove the switches.
Each switch has small tabs on the corners to grab and remove them. (The Included switch puller might require extra strength to remove)
Use a # 1 philips drill bit to remove the 4 screws on the keyboard
Use a spudger or another wedge tool to pry open the plastic base from the aluminum chassis.
Remove the 14 screws with a # 1 Philips screw driver bit
To remove the PCB from the aluminum frame, use a spudger to wedge it out.
4 andere personen hebben deze handleiding voltooid.
4 opmerkingen
Feel free to leave advice if you think I should change any steps. This is my first guide. Enjoy!
Hi Mike,
Great job! Check out this article on creating guides–it has some great tips! Looking forward to reading your next one!
Do you know what size screws the keyboard uses?
Does anyone know where I can get a replacement battery for this keyboard?
