Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Firmly place a finger on each one of the three tabs that hold the K-cup holder into place, pushing in lightly. The tabs are difficult to see, but they are there and will make the removal easier. The top tab is located in the same location as the white triangle and the bottom two are located under the plastic bumps highlighted in the picture.
Firmly rock the K-cup holder from side to side, loosening the K-cup holder from its seat.
Open the top lid of the Keurig.
Pull directly outwards on one of the arms that holds the top lid in place. It will take some force to get the arm off the peg. Once one side is off, repeat the process on the second arm.
Lay the Keurig on its back with the water reservoir pointing away from you.
Unscrew the two 9mm #1 Philips screws that hold the top plastic cover in place.
Set the Keurig in an upright position with the front side facing you.
Pull the cover off the top of the Keurig. It should come off easily with little force.
Firmly grasp the hose and pull it off of the plastic nozzle.
Unscrew the two 9 mm #1 Philips screws at the top of the device.
Push down lightly on the nozzle that the hose was attached to. The plastic housing along with the needle should pop off without much force.
Één andere persoon heeft deze handleiding voltooid.
