Inleiding
Regular usage of this device may cause the K-cup holder to clog or accidentally crack. This guide will show you how to remove a K-cup holder for either cleaning or replacement for your Keurig Mini B-31.
Wat je nodig hebt
Firmly place a finger on each one of the three tabs that hold the K-cup holder into place, pushing in lightly. The tabs are difficult to see, but they are there and will make the removal easier. The top tab is located in the same location as the white triangle and the bottom two are located under the plastic bumps highlighted in the picture.
You may want to show a picture of the needles to show what exactly to avoid even though it might be blatantly obvious.
You should write "They" between "inside the K-cup because" and "may puncture your hand"
I did the needle up the 2 pin hole trick and it's working now!
What is a needle up the 2 pin hole trick?
Gina -
7 andere personen hebben deze handleiding voltooid.
2 opmerkingen
See here for k-cup holder removal.
