Inleiding
Is your Keurig K55 K lid not staying open? If so, you might have a broken or missing spring. Here's a guide to replace the Keurig K55 Lid Spring.
Wat je nodig hebt
Lift the silver handle up.
Locate the screw and washer holding the handle in place on each side.
Remove both 13mm screws and washers using a Phillips #0 screwdriver.
Één andere persoon heeft deze handleiding voltooid.
