Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Unscrew both 1.5mm screws located on the water pump.
Keeping one hand firmly placed on the device, tug upwards on the water pump until it is separated from the device.
The water pump and pipe should now be loose and easy to move as shown.
Pull on the point where the pipe meets the water pump.
The pipe will come loose and the water filter will be free and ready to be replaced.
5 andere personen hebben deze handleiding voltooid.
4 opmerkingen
I viewed this to replace the pump. But after the checkvalve was replaced through these instructions my K40 works like new. Thank you.
