Inleiding
In this guide the user will open the top unit of the Keurig and replace the sensor that tells the device if the head unit is open or closed.
Wat je nodig hebt
Using a #2 Philips head screwdriver remove the 1.2mm screw holding the sensor in place.
Locate where the connections are soldered to the sensor
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Where can I get the open/closed sensor? I called Keurig and they told me they don’t handle them.
