Ga door naar hoofdinhoud
Keurig K40 Open/Close Sensor Replacement
Wat je nodig hebt
  1. Keurig K40 Open/Close Sensor Replacement, Top Water Pump: stap 1, afbeelding 1 van 1
    • Begin by removing the top cover from the device.
    • Remove the cover by gently rocking it back and forth with an emphasis on lowering the left side underneath an internal peg.
  2. Keurig K40 Open/Close Sensor Replacement: stap 2, afbeelding 1 van 1
    • Unscrew both 1.5mm screws located on the water pump.
  3. Keurig K40 Open/Close Sensor Replacement: stap 3, afbeelding 1 van 2 Keurig K40 Open/Close Sensor Replacement: stap 3, afbeelding 2 van 2
    • Keeping one hand firmly placed on the device, tug upwards on the water pump until it is separated from the device.
    • The water pump and pipe should now be loose and easy to move as shown.
  4. Keurig K40 Open/Close Sensor Replacement: stap 4, afbeelding 1 van 2 Keurig K40 Open/Close Sensor Replacement: stap 4, afbeelding 2 van 2
    • Pull on the point where the pipe meets the water pump.
    • The pipe will come loose and the water filter will be free and ready to be replaced.
  5. Keurig K40 Open/Close Sensor Replacement, Open/Closed Sensor: stap 5, afbeelding 1 van 2 Keurig K40 Open/Close Sensor Replacement, Open/Closed Sensor: stap 5, afbeelding 2 van 2
    • Using a #2 Philips head screwdriver remove the 1.2mm screw holding the sensor in place.
    • Locate where the connections are soldered to the sensor
  6. Keurig K40 Open/Close Sensor Replacement: stap 6, afbeelding 1 van 1
    • Melt the solder that is connected to the sensor.
    • Be careful to avoid any rubber and try to only contact the metal making the connection.
  7. Keurig K40 Open/Close Sensor Replacement: stap 7, afbeelding 1 van 1
    • Put the replacement sensor back on the post that holds it and begin to solder the two metal connections back to the sensor.
    • Be careful not to touch the end of the soldering iron.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
jonathan
711 Reputatie
2 handleidingen geschreven
USF Tampa, Team 6-1, Eyestone Spring 2016 Lid van USF Tampa, Team 6-1, Eyestone Spring 2016
USFT-EYESTONE-S16S6G1
3 Leden
5 handleidingen geschreven
Één opmerking
Where can I get the open/closed sensor? I called Keurig and they told me they don’t handle them.
John Fictum - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 21
Altijd: 3,740
