Ga door naar hoofdinhoud
Keurig K10 Mini Plus Cup Holder Replacement
Wat je nodig hebt
  1. Keurig K10 Mini Plus Cup Holder Replacement, Cup Holder: stap 1, afbeelding 1 van 3 Keurig K10 Mini Plus Cup Holder Replacement, Cup Holder: stap 1, afbeelding 2 van 3 Keurig K10 Mini Plus Cup Holder Replacement, Cup Holder: stap 1, afbeelding 3 van 3
    • Press on tab while pulling up on K-cup until you hear a click. Repeat for the remaining tabs. We found using the smallest of the "plastic opening tools" worked wonders.
  2. Keurig K10 Mini Plus Cup Holder Replacement: stap 2, afbeelding 1 van 2 Keurig K10 Mini Plus Cup Holder Replacement: stap 2, afbeelding 2 van 2
    • Once all of the tabs have been pressed, the K-Cup should just pop out. After, you just pull the remainder of the K-Cup. You have successfully removed the K-Cup.
Conclusie
Mark Henein
369 Reputatie
2 handleidingen geschreven
USF Tampa, Team 17-6, Blackwell Winter 2016 Lid van USF Tampa, Team 17-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G6
2 Leden
Één opmerking
I accidentally removed the k cup holder while wiping it out. Now I have the holder plus 3 small plastic and 1 rubber circular pieces. How do I put it back together again? I have the same Kuerig mini as pictured here.
Marie - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 23
Altijd: 1,514
