Ga door naar hoofdinhoud
Keurig B70 Platinum Water Filter Replacement
Wat je nodig hebt
  1. Keurig B70 Platinum Water Filter Replacement, Water Filter: stap 1, afbeelding 1 van 3 Keurig B70 Platinum Water Filter Replacement, Water Filter: stap 1, afbeelding 2 van 3 Keurig B70 Platinum Water Filter Replacement, Water Filter: stap 1, afbeelding 3 van 3
    • Remove the water reservoir from the Keurig by lifting it upwards and pulling it outwards.
    • Be sure to empty the reservoir before continuing to the next step.
  2. Keurig B70 Platinum Water Filter Replacement: stap 2, afbeelding 1 van 3 Keurig B70 Platinum Water Filter Replacement: stap 2, afbeelding 2 van 3 Keurig B70 Platinum Water Filter Replacement: stap 2, afbeelding 3 van 3
    • Remove the three 11.0 mm screws from the reservoir filter.
    • You may need to use tweezers to pull out the screws.
  3. Keurig B70 Platinum Water Filter Replacement: stap 3, afbeelding 1 van 3 Keurig B70 Platinum Water Filter Replacement: stap 3, afbeelding 2 van 3 Keurig B70 Platinum Water Filter Replacement: stap 3, afbeelding 3 van 3
    • Firmly twist the filter counterclockwise to remove it.
    • When adding the replacement filter, make sure the filter lines up with the screw holes.
Conclusie
Emily Ramirez
97 Reputatie
1 Handleiding geschreven
UW Tacoma, Team S1-G6, Rose Fall 2018 Lid van UW Tacoma, Team S1-G6, Rose Fall 2018
UWT-ROSE-F18S1G6
4 Leden
5 handleidingen geschreven
4 opmerkingen
What are the two items inside the water resin?
There is the round item, and next to it an oblong item. I am really confused
Joan - Antwoord
The round item with 3 screws is the built in filter. The oblong item is the water level gauge.
Dacaria L -
I just ordered a filter starter kit. Do I just insert the kit on top of the round item?
Joan - Antwoord
I bought a Kuerig tall handle starter kit with charcoal filters. Tried install it over the existing built in filter, it didn’t fit. I think the round filter has to be removed in order to use the starter kit.
Dacaria L -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 89
Altijd: 10,414
