Ga door naar hoofdinhoud
Kenwood KDC-BT565U Fuse Replacement
Wat je nodig hebt
  1. Kenwood KDC-BT565U Fuse Replacement, Fuse: stap 1, afbeelding 1 van 1
    • The fuse can be found on the back of your radio indicated by the red square in the photo.
  2. Kenwood KDC-BT565U Fuse Replacement: stap 2, afbeelding 1 van 2 Kenwood KDC-BT565U Fuse Replacement: stap 2, afbeelding 2 van 2
    • Pinch the fuse head with your fingers or a gripping tool to remove. This may require some force.
    • Reinsert a fuse that has the same amperage of the fuse that was previously removed (10 amps).
Conclusie
To reassemble, follow these instructions in reverse order.
4 andere personen hebben deze handleiding voltooid.
Darren Evans
273 Reputatie
2 handleidingen geschreven
USF Tampa, Team S2-G5, Lacy Spring 2017 Lid van USF Tampa, Team S2-G5, Lacy Spring 2017
USFT-LACY-S17S2G5
4 Leden
11 handleidingen geschreven
7 opmerkingen
I disconnect the negative side on my 502 DPX Kenwood in-dash stereo system I replace the alternator and hook everything back up and now I have no power to the receiver
jasonfisher036@gmail.com - Antwoord
it does not explain how to pull the reciever out.
d_lalande - Antwoord
same problem, how to remove the receiver
Jason Armondo - Antwoord
I accidentally touch power on the radio casing now the radio will not turn on and the fuse is good I need help it’s a kenwood KDC-7011
Javier Castellanos - Antwoord
Did you ever find problem why your radio wouldn't turn on? Can you share with me. I have same problem
Jannie watkins -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 35
Afgelopen 30 dagen: 223
Altijd: 21,983
