Ga door naar hoofdinhoud
Kenwood DRV-N520 Dashcam Speaker Replacement
Wat je nodig hebt
  1. Kenwood DRV-N520 Dashcam Speaker Replacement, Speaker: stap 1, afbeelding 1 van 3 Kenwood DRV-N520 Dashcam Speaker Replacement, Speaker: stap 1, afbeelding 2 van 3 Kenwood DRV-N520 Dashcam Speaker Replacement, Speaker: stap 1, afbeelding 3 van 3
    • Use a Phillips #0 screwdriver to remove the four 3mm screws from the device backing.
    • Remove the backing.
  2. Kenwood DRV-N520 Dashcam Speaker Replacement: stap 2, afbeelding 1 van 3 Kenwood DRV-N520 Dashcam Speaker Replacement: stap 2, afbeelding 2 van 3 Kenwood DRV-N520 Dashcam Speaker Replacement: stap 2, afbeelding 3 van 3
    • Use a Phillips #0 screwdriver to remove the four 3mm screws in the copper plate.
    • Remove the copper plate from the housing. The motherboard and capacitors should now be visible.
  3. Kenwood DRV-N520 Dashcam Speaker Replacement: stap 3, afbeelding 1 van 2 Kenwood DRV-N520 Dashcam Speaker Replacement: stap 3, afbeelding 2 van 2
    • Use the screwdriver to remove the two screws holding the motherboard in place.
    • Before attempting to remove the board, disconnect the camera by removing the ribbon cable from its corresponding connection on the board.
    • To remove the ribbon cable, use a plastic spudger to gently apply pressure to the lever that secures the cable in place while simultaneously applying a light pulling pressure on the ribbon cable.
    • Disconnect the speaker connections (red and black wires) from the motherboard by applying pressure to the clip on its corresponding socket.
    • Once all connections have been severed, gently remove the motherboard from the device casing.
    • The speaker unit and corresponding mounting hardware should now be visible.
  4. Kenwood DRV-N520 Dashcam Speaker Replacement: stap 4, afbeelding 1 van 2 Kenwood DRV-N520 Dashcam Speaker Replacement: stap 4, afbeelding 2 van 2
    • Use your Phillips #0 screwdriver to remove the two 3mm screws from the speaker's mounting bracket.
    • Remove the speaker from the device.
Conclusie
To re-assemble your device, follow these steps in reverse order.
NathanGoodwin
136 Reputatie
1 Handleiding geschreven
ERAU-LAMOTHE-S20S14G1 Lid van ERAU-LAMOTHE-S20S14G1
Local Repair Groups
4 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 161
