Ga door naar hoofdinhoud
Kenwood DRV-N520 Dashcam Motherboard Replacement
Wat je nodig hebt
  1. Kenwood DRV-N520 Dashcam Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to remove the four 3mm screws in the device backing.
    • Remove the back cover.
  2. Kenwood DRV-N520 Dashcam Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the four 3mm screws in the copper plate using a Phillips #0 screwdriver.
    • Remove the copper plate to gain access to the motherboard.
  3. Kenwood DRV-N520 Dashcam Motherboard Replacement: stap 3, afbeelding 1 van 2 Kenwood DRV-N520 Dashcam Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Remove the ribbon cable by gently pulling on it while using a spudger to apply pressure to the lever (orange arrow) holding it in place.
  4. Kenwood DRV-N520 Dashcam Motherboard Replacement: stap 4, afbeelding 1 van 3 Kenwood DRV-N520 Dashcam Motherboard Replacement: stap 4, afbeelding 2 van 3 Kenwood DRV-N520 Dashcam Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Disconnect the speaker connection from the circuit board by using your fingers to apply pressure to the clip holding it in place.
    • Finally, remove the two screws from the two corners of the motherboard using a Phillips #0 screwdriver.
    • Remove the motherboard from the device.
Conclusie
This will conclude the removal of the circuit card. Please refer to the troubleshooting guide for any question.
Één opmerking
I have a fault with the G FORCE sensor on my device. Any advise on how to deactivate or remove the sensor.
tomle3 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 22
Altijd: 202
