Ga door naar hoofdinhoud
Kenwood DNX571HD LCD Touch Screen Replacement
Wat je nodig hebt
  1. Kenwood DNX571HD LCD Touch Screen Replacement, LCD Touch Screen: stap 1, afbeelding 1 van 2 Kenwood DNX571HD LCD Touch Screen Replacement, LCD Touch Screen: stap 1, afbeelding 2 van 2
    • Turn off the stereo and remove from the vehicle before starting.
    • Unscrew the four 3.5mm side screws with a Phillips #1 screwdriver.
    • There are two screws per side.
  2. Kenwood DNX571HD LCD Touch Screen Replacement: stap 2, afbeelding 1 van 3 Kenwood DNX571HD LCD Touch Screen Replacement: stap 2, afbeelding 2 van 3 Kenwood DNX571HD LCD Touch Screen Replacement: stap 2, afbeelding 3 van 3
    • Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
    • Place the spudger between the plastic tab and the metal case and gently lift the spudger away from the case.
  3. Kenwood DNX571HD LCD Touch Screen Replacement: stap 3, afbeelding 1 van 1
    • Pull the top of the front panel out and down to remove front panel.
    • Remove the front panel gently so as not to damage the ribbon cables behind it.
  4. Kenwood DNX571HD LCD Touch Screen Replacement: stap 4, afbeelding 1 van 2 Kenwood DNX571HD LCD Touch Screen Replacement: stap 4, afbeelding 2 van 2
    • Flip up the black clasp with the spudger to disconnect the small white ribbon cable from the main board.
  5. Kenwood DNX571HD LCD Touch Screen Replacement: stap 5, afbeelding 1 van 2 Kenwood DNX571HD LCD Touch Screen Replacement: stap 5, afbeelding 2 van 2
    • Flip up the black clasp with the spudger to disconnect the large white ribbon cable from the main board.
  6. Kenwood DNX571HD LCD Touch Screen Replacement: stap 6, afbeelding 1 van 2 Kenwood DNX571HD LCD Touch Screen Replacement: stap 6, afbeelding 2 van 2
    • Flip up the black clasp with the spudger to disconnect the small white ribbon cable from the vertical board.
    • Carefully pull the ribbon from the clasp with the spudger.
  7. Kenwood DNX571HD LCD Touch Screen Replacement: stap 7, afbeelding 1 van 2 Kenwood DNX571HD LCD Touch Screen Replacement: stap 7, afbeelding 2 van 2
    • Flip up the black clasp with the spudger to disconnect the large orange ribbon cable from the main board.
  8. Kenwood DNX571HD LCD Touch Screen Replacement: stap 8, afbeelding 1 van 2 Kenwood DNX571HD LCD Touch Screen Replacement: stap 8, afbeelding 2 van 2
    • Push out the black clasp with the spudger to disconnect the small orange ribbon cable from the main board.
    • Gently push the ribbon out of the clasp with the spudger.
  9. Kenwood DNX571HD LCD Touch Screen Replacement: stap 9, afbeelding 1 van 2 Kenwood DNX571HD LCD Touch Screen Replacement: stap 9, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Using a pair of tweezers, gently pull up on the connector for the power cable to disconnect it from the main board.
  10. Kenwood DNX571HD LCD Touch Screen Replacement: stap 10, afbeelding 1 van 2 Kenwood DNX571HD LCD Touch Screen Replacement: stap 10, afbeelding 2 van 2
    • Unscrew the two 4mm screws holding down the board that is standing vertically with a Phillips #1 screwdriver.
    • Pull up on the board to remove it.
  11. Kenwood DNX571HD LCD Touch Screen Replacement: stap 11, afbeelding 1 van 2 Kenwood DNX571HD LCD Touch Screen Replacement: stap 11, afbeelding 2 van 2
    • Unscrew the four 5.5mm screws with a JIS #00 screwdriver.
    • Unscrew the 4mm screw with a Phillips #1 screwdriver.
    • Remove the disconnected circuit board.
  12. Kenwood DNX571HD LCD Touch Screen Replacement: stap 12, afbeelding 1 van 2 Kenwood DNX571HD LCD Touch Screen Replacement: stap 12, afbeelding 2 van 2
    • Unscrew the four 4mm screws on the main board with a Phillips #1 screwdriver.
    • Gently lift the board out of the casing.
    • Unscrew the 5.5mm screw on the metal plate with a JIS #00 screwdriver.
  13. Kenwood DNX571HD LCD Touch Screen Replacement: stap 13, afbeelding 1 van 1
    • Carefully remove the tape attaching the power cable to the metal plate.
  14. Kenwood DNX571HD LCD Touch Screen Replacement: stap 14, afbeelding 1 van 2 Kenwood DNX571HD LCD Touch Screen Replacement: stap 14, afbeelding 2 van 2
    • Use the spudger to unhook the metal tabs and detach the metal plate from the plastic housing.
    • Place the spudger between the metal tab and the plastic case and gently lift the spudger away from the case.
  15. Kenwood DNX571HD LCD Touch Screen Replacement: stap 15, afbeelding 1 van 2 Kenwood DNX571HD LCD Touch Screen Replacement: stap 15, afbeelding 2 van 2
    • Gently press the front of the screen to detach it from the plastic housing.
    • When removing the screen, gently flex out the plastic housing to help get the display past the plastic latch.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Wendy Zaballos
952 Reputatie
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 74
Altijd: 9,248
