Ga door naar hoofdinhoud
Kenwood DNX571HD GPS Antenna Connection Replacement
Wat je nodig hebt
  1. Kenwood DNX571HD GPS Antenna Connection Replacement, CD/DVD Drive: stap 1, afbeelding 1 van 2 Kenwood DNX571HD GPS Antenna Connection Replacement, CD/DVD Drive: stap 1, afbeelding 2 van 2
    • Unscrew the four 3.5mm side screws with a Phillips #1 screwdriver.
    • There are two screws per side.
  2. Kenwood DNX571HD GPS Antenna Connection Replacement: stap 2, afbeelding 1 van 3 Kenwood DNX571HD GPS Antenna Connection Replacement: stap 2, afbeelding 2 van 3 Kenwood DNX571HD GPS Antenna Connection Replacement: stap 2, afbeelding 3 van 3
    • Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
    • Place the spudger between the plastic tab and the metal case and gently lift the spudger away from the case.
  3. Kenwood DNX571HD GPS Antenna Connection Replacement: stap 3, afbeelding 1 van 1
    • Pull the top of the front panel out and down to remove front panel.
    • Remove the front panel gently so as not to damage the ribbon cables behind it.
  4. Kenwood DNX571HD GPS Antenna Connection Replacement: stap 4, afbeelding 1 van 3 Kenwood DNX571HD GPS Antenna Connection Replacement: stap 4, afbeelding 2 van 3 Kenwood DNX571HD GPS Antenna Connection Replacement: stap 4, afbeelding 3 van 3
    • Unscrew the three 5mm screws from the top of the device using a Phillips #1 screwdriver.
    • Lift up to remove the top casing.
  5. Kenwood DNX571HD GPS Antenna Connection Replacement: stap 5, afbeelding 1 van 1
    • Lift the CD drive carefully to expose the attached cable underneath.
  6. Kenwood DNX571HD GPS Antenna Connection Replacement: stap 6, afbeelding 1 van 2 Kenwood DNX571HD GPS Antenna Connection Replacement: stap 6, afbeelding 2 van 2
    • Flip up the black clasp with a spudger to disconnect the large white ribbon cable connecting the CD drive to the board underneath.
  7. Kenwood DNX571HD GPS Antenna Connection Replacement, Cooling Fan: stap 7, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Carefully unplug the fan power cord with the tweezers.
  8. Kenwood DNX571HD GPS Antenna Connection Replacement: stap 8, afbeelding 1 van 2 Kenwood DNX571HD GPS Antenna Connection Replacement: stap 8, afbeelding 2 van 2
    • Unscrew the three 5mm length screws with the Phillips #1 screwdriver.
    • Remove the metal plate
    • Removing the plate will damage the heat sink compound. This will need to be replaced during reassembly.
  9. Kenwood DNX571HD GPS Antenna Connection Replacement: stap 9, afbeelding 1 van 2 Kenwood DNX571HD GPS Antenna Connection Replacement: stap 9, afbeelding 2 van 2
    • Unscrew the three 5.5mm long screws with a Phillips #1 screwdriver.
  10. Kenwood DNX571HD GPS Antenna Connection Replacement: stap 10, afbeelding 1 van 3 Kenwood DNX571HD GPS Antenna Connection Replacement: stap 10, afbeelding 2 van 3 Kenwood DNX571HD GPS Antenna Connection Replacement: stap 10, afbeelding 3 van 3
    • Remove the four 5.5mm screws with the Phillips #1 screwdriver.
  11. Kenwood DNX571HD GPS Antenna Connection Replacement: stap 11, afbeelding 1 van 1
    • Lift the top part of the unit up from the lower chassis.
  12. Kenwood DNX571HD GPS Antenna Connection Replacement: stap 12, afbeelding 1 van 2 Kenwood DNX571HD GPS Antenna Connection Replacement: stap 12, afbeelding 2 van 2
    • Remove the two 13mm long screws with a Phillips #1 screwdriver.
    • Gently thread the power cable through the circuit boards to separate the fan from the body of the stereo.
  13. Kenwood DNX571HD GPS Antenna Connection Replacement, GPS Antenna Connection: stap 13, afbeelding 1 van 2 Kenwood DNX571HD GPS Antenna Connection Replacement, GPS Antenna Connection: stap 13, afbeelding 2 van 2
    • Using a spudger, undo the clasp to disconnect the large white ribbon cable.
  14. Kenwood DNX571HD GPS Antenna Connection Replacement: stap 14, afbeelding 1 van 1
    • Remove the 5mm screw with teeth from the casing with a Phillips #1 screwdriver.
  15. Kenwood DNX571HD GPS Antenna Connection Replacement: stap 15, afbeelding 1 van 1
    • Remove the four 5mm screws with a Phillips #1 screwdriver.
  16. Kenwood DNX571HD GPS Antenna Connection Replacement: stap 16, afbeelding 1 van 2 Kenwood DNX571HD GPS Antenna Connection Replacement: stap 16, afbeelding 2 van 2
    • Remove the 5.5mm screw from the HDMI cable cover using a Phillips #2 screwdriver.
  17. Kenwood DNX571HD GPS Antenna Connection Replacement: stap 17, afbeelding 1 van 1
    • Remove the 5mm screw with a Phillips #1 screwdriver.
  18. Kenwood DNX571HD GPS Antenna Connection Replacement: stap 18, afbeelding 1 van 2 Kenwood DNX571HD GPS Antenna Connection Replacement: stap 18, afbeelding 2 van 2
    • Remove the two 5.5mm screws from the back.
    • Lift the upper portion of the stereo free from the chassis.
  19. Kenwood DNX571HD GPS Antenna Connection Replacement: stap 19, afbeelding 1 van 2 Kenwood DNX571HD GPS Antenna Connection Replacement: stap 19, afbeelding 2 van 2
    • Remove the two screws underneath the GPS connector.
    • Desolder the GPS connector.
    • The GPS antenna is a thru-hole-mounted device. You must apply heat to each soldered pin individually and pull them out of the holes while the solder is molten.
    • The solder material, pins, and any surrounding material will get VERY hot while melting the connections. Do not touch any metal parts during the desoldering process and give the device time to cool off once you’re finished. It may also be good to take breaks so that the electronics aren’t kept hot for extended periods of time.
  20. Kenwood DNX571HD GPS Antenna Connection Replacement: stap 20, afbeelding 1 van 1
    • To remove and reinsert the connector, on the top side of the board, use your finger to gently lift the metal plate to get enough clearance.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Wendy Zaballos
952 Reputatie
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 15
Altijd: 854
