Ga door naar hoofdinhoud
Kenwood DNX571HD Cooling Fan Replacement
Wat je nodig hebt
  1. Kenwood DNX571HD Cooling Fan Replacement, CD/DVD Drive: stap 1, afbeelding 1 van 2 Kenwood DNX571HD Cooling Fan Replacement, CD/DVD Drive: stap 1, afbeelding 2 van 2
    • Unscrew the four 3.5mm side screws with a Phillips #1 screwdriver.
    • There are two screws per side.
  2. Kenwood DNX571HD Cooling Fan Replacement: stap 2, afbeelding 1 van 3 Kenwood DNX571HD Cooling Fan Replacement: stap 2, afbeelding 2 van 3 Kenwood DNX571HD Cooling Fan Replacement: stap 2, afbeelding 3 van 3
    • Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
    • Place the spudger between the plastic tab and the metal case and gently lift the spudger away from the case.
  3. Kenwood DNX571HD Cooling Fan Replacement: stap 3, afbeelding 1 van 1
    • Pull the top of the front panel out and down to remove front panel.
    • Remove the front panel gently so as not to damage the ribbon cables behind it.
  4. Kenwood DNX571HD Cooling Fan Replacement: stap 4, afbeelding 1 van 3 Kenwood DNX571HD Cooling Fan Replacement: stap 4, afbeelding 2 van 3 Kenwood DNX571HD Cooling Fan Replacement: stap 4, afbeelding 3 van 3
    • Unscrew the three 5mm screws from the top of the device using a Phillips #1 screwdriver.
    • Lift up to remove the top casing.
  5. Kenwood DNX571HD Cooling Fan Replacement: stap 5, afbeelding 1 van 1
    • Lift the CD drive carefully to expose the attached cable underneath.
  6. Kenwood DNX571HD Cooling Fan Replacement: stap 6, afbeelding 1 van 2 Kenwood DNX571HD Cooling Fan Replacement: stap 6, afbeelding 2 van 2
    • Flip up the black clasp with a spudger to disconnect the large white ribbon cable connecting the CD drive to the board underneath.
  7. Kenwood DNX571HD Cooling Fan Replacement, Cooling Fan: stap 7, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Carefully unplug the fan power cord with the tweezers.
  8. Kenwood DNX571HD Cooling Fan Replacement: stap 8, afbeelding 1 van 2 Kenwood DNX571HD Cooling Fan Replacement: stap 8, afbeelding 2 van 2
    • Unscrew the three 5mm length screws with the Phillips #1 screwdriver.
    • Remove the metal plate
    • Removing the plate will damage the heat sink compound. This will need to be replaced during reassembly.
  9. Kenwood DNX571HD Cooling Fan Replacement: stap 9, afbeelding 1 van 2 Kenwood DNX571HD Cooling Fan Replacement: stap 9, afbeelding 2 van 2
    • Unscrew the three 5.5mm long screws with a Phillips #1 screwdriver.
  10. Kenwood DNX571HD Cooling Fan Replacement: stap 10, afbeelding 1 van 3 Kenwood DNX571HD Cooling Fan Replacement: stap 10, afbeelding 2 van 3 Kenwood DNX571HD Cooling Fan Replacement: stap 10, afbeelding 3 van 3
    • Remove the four 5.5mm screws with the Phillips #1 screwdriver.
  11. Kenwood DNX571HD Cooling Fan Replacement: stap 11, afbeelding 1 van 1
    • Lift the top part of the unit up from the lower chassis.
  12. Kenwood DNX571HD Cooling Fan Replacement: stap 12, afbeelding 1 van 2 Kenwood DNX571HD Cooling Fan Replacement: stap 12, afbeelding 2 van 2
    • Remove the two 13mm long screws with a Phillips #1 screwdriver.
    • Gently thread the power cable through the circuit boards to separate the fan from the body of the stereo.
Conclusie
Wendy Zaballos
952 Reputatie
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 910
