Ga door naar hoofdinhoud
Kenwood DNX571HD CD/DVD Drive Replacement
Wat je nodig hebt
  1. Kenwood DNX571HD CD/DVD Drive Replacement, CD/DVD Drive: stap 1, afbeelding 1 van 2 Kenwood DNX571HD CD/DVD Drive Replacement, CD/DVD Drive: stap 1, afbeelding 2 van 2
    • Unscrew the four 3.5mm side screws with a Phillips #1 screwdriver.
    • There are two screws per side.
  2. Kenwood DNX571HD CD/DVD Drive Replacement: stap 2, afbeelding 1 van 3 Kenwood DNX571HD CD/DVD Drive Replacement: stap 2, afbeelding 2 van 3 Kenwood DNX571HD CD/DVD Drive Replacement: stap 2, afbeelding 3 van 3
    • Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
    • Place the spudger between the plastic tab and the metal case and gently lift the spudger away from the case.
  3. Kenwood DNX571HD CD/DVD Drive Replacement: stap 3, afbeelding 1 van 1
    • Pull the top of the front panel out and down to remove front panel.
    • Remove the front panel gently so as not to damage the ribbon cables behind it.
  4. Kenwood DNX571HD CD/DVD Drive Replacement: stap 4, afbeelding 1 van 3 Kenwood DNX571HD CD/DVD Drive Replacement: stap 4, afbeelding 2 van 3 Kenwood DNX571HD CD/DVD Drive Replacement: stap 4, afbeelding 3 van 3
    • Unscrew the three 5mm screws from the top of the device using a Phillips #1 screwdriver.
    • Lift up to remove the top casing.
  5. Kenwood DNX571HD CD/DVD Drive Replacement: stap 5, afbeelding 1 van 1
    • Lift the CD drive carefully to expose the attached cable underneath.
  6. Kenwood DNX571HD CD/DVD Drive Replacement: stap 6, afbeelding 1 van 2 Kenwood DNX571HD CD/DVD Drive Replacement: stap 6, afbeelding 2 van 2
    • Flip up the black clasp with a spudger to disconnect the large white ribbon cable connecting the CD drive to the board underneath.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Wendy Zaballos
952 Reputatie
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 1,107
