Ga door naar hoofdinhoud
Inleiding
Here is a Kenmore 400 model 11029422801 with a clutch that was slipping. The washer went through all the programs but left the laundry soaking wet after the spin cycle. It sounded like it was spinning, but when we checked the drum while spinning, we noticed that it was not achieving full spinning speed. This was most evident on heavy loads.
  1. Kenmore 400 washer that has difficulty spinning. It runs through the cycle but does not spin properly. Open the lid Remove cap from the agitator by using a flat tip screwdriver or similar.
    • Kenmore 400 washer that has difficulty spinning. It runs through the cycle but does not spin properly.
    • Open the lid
    • Remove cap from the agitator by using a flat tip screwdriver or similar.
  2. With the cap removed, a 7/16 hex bolt becomes visible. Use a socket wrench with 4 inch extension to remove the bolt. The agitator bolt measures 5/16 X 1 inches, 24 thread size
    • With the cap removed, a 7/16 hex bolt becomes visible.
    • Use a socket wrench with 4 inch extension to remove the bolt.
    • The agitator bolt measures 5/16 X 1 inches, 24 thread size
  3. With the bolt removed, pull the agitator of the shaft. View of the drum with agitator removed For ease of working on the bottom parts, lay the washer on its side.
    • With the bolt removed, pull the agitator of the shaft.
    • View of the drum with agitator removed
    • For ease of working on the bottom parts, lay the washer on its side.
  4. Main parts of the assembly include Drain pump Motor
    • Main parts of the assembly include
    • Drain pump
    • Motor
    • Transmission
    • This is a direct drive model. No belts but a motor coupler connects the motor to transmission. Check for any cracks etc.
    • Remove the wiring harness from the motor
  5. Remove the wiring harness from the clip on the transmission Drain lines from the drum and drain hose are connected to the pump with spring clamps. Using a pair of pliers and squeezinge the opposite ends of the clamps together will loosen the clamp.
    • Remove the wiring harness from the clip on the transmission
    • Drain lines from the drum and drain hose are connected to the pump with spring clamps.
    • Using a pair of pliers and squeezinge the opposite ends of the clamps together will loosen the clamp.
  6. Pull the drain hose of the pump Remove the tub-to-pump hose  the same way Remove the three 1/2inch bolts.
    • Pull the drain hose of the pump
    • Remove the tub-to-pump hose the same way
    • Remove the three 1/2inch bolts.
  7. Here are the three bolts. They are 5/16 by 11/16 with a 1/2 inch hex head. With the three bolts removed, pull the complete assembly out of the drum With the assembly removed, the clutch is now completely visible.
    • Here are the three bolts. They are 5/16 by 11/16 with a 1/2 inch hex head.
    • With the three bolts removed, pull the complete assembly out of the drum
    • With the assembly removed, the clutch is now completely visible.
  8. It is not necessary to replace the whole clutch. For this repair only the clutch band needs to be replaced Using a pair of pliers to compress the spring will loosen the clutch band. Lift the clutch band out of the clutch housing
    • It is not necessary to replace the whole clutch. For this repair only the clutch band needs to be replaced
    • Using a pair of pliers to compress the spring will loosen the clutch band.
    • Lift the clutch band out of the clutch housing
    • Clutch band removed. Replace with model specific part.
Conclusie
6 andere personen hebben deze handleiding voltooid.
oldturkey03
606.843 Reputatie
103 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 8
Afgelopen 7 Dagen: 53
Afgelopen 30 Dagen: 273
Altijd: 16,391
